Old 11-25-2008, 06:05 PM   #1
RedCoupe818
RedCoupe818's Avatar
RedCoupe818 is an unknown quantity at this point
Question shock bolts removal problem!
I just bought brand new shocks and springs for my worn out suspension and i've been trying to install them my self but theres one big problem i can't seem to get the two lower bolts off the shock connecting it to the suspension, I've tried penetrating oil and WD-40 and went at it with an Impact wrench but they still don't come out . Has anyone else had this problem??
RedCoupe818 is offline   Reply With Quote
Old 11-25-2008, 06:16 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
By two lower bolts I assume your talking about front strut, make sure your using 6 point socket and use the impact from the nut side not the bolt use a wrench to hold the bolt head. Also you have to get an alignment asap after you change everything out. and be sure to drive much after you change unless you just going straight to the alignment place.
Old 11-25-2008, 06:21 PM   #3
projectRDM
projectRDM's Avatar
I'm guessing the nuts are already off? I've had a few cars do that, the bolt seizes into the spindle from corrosion. Go ahead and order new bolts and start beating the old ones with a hammer, the ends will crown and make them worthless. The last one I did I ended up taking the spindle off completely and hitting the bolts with a 48" sledgehammer before they broke loose. Maybe you'll be luckier, but it's a common thing to happen. Sand the spindle holes out really well once they're free and dip the bolts in a little grease, keeps it from happening again.
FORMERLY R240NA
Old 11-25-2008, 06:37 PM   #4
RedCoupe818
I'm sorry i should of been more specific about that ,but the nuts and bolts are still on . they won't loosen
Old 11-25-2008, 06:29 PM   #5
RedCoupe818
mm.. maybe that's why, Im not using a 6 point socket i used the multi point star kind.. I'll see if i can get my hands on one.. thanks dude..
Old 11-25-2008, 08:00 PM   #6
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
failing that, use a socket that is 1 mm smaller. if it is really stubborn heat the nut to expand nut and break rust bond. hit with hammer etc
dont reinvent the wheel:
Suspension: Front Struts
Suspension: Rear shocks
surreybc is offline   Reply With Quote
Old 11-25-2008, 08:47 PM   #7
RedCoupe818
If it fails i'll be sure to try this. thanks surrey!
Old 11-25-2008, 11:51 PM   #8
s13 @ fullboost
your very welcome if you need anything else let me know =]
Old 11-25-2008, 06:18 PM   #9
murda-c
murda-c's Avatar
6 foot breaker bar gets everything off.
also don't forget to use the torch.
