![]() Join Date: Oct 2008
summit fuel pump?
Ok i have been searching for a affordable fuel pump to power my s13 sr. I would just but a walbro but the sr is in my rx8 wich nobody makes a in tank pump for. Ive found a inline pump that is a summit brand and flows 43 gph @ up to 85 psi. will this be sufficent for a basicly stock sr with a few bolt ons a emanage and Eo1.. the item # is sum-g3138. and just for the ones that havent seen it heres a pic , and there is a thread here about it.
#2 | |
![]() Join Date: Apr 2004
I have a fuel cell and an external pump. The pickup is at the bottom of the tank and has a special design to gravity feed the fuel pump. I don't know if you can do that with a stock pump. I know that even with Walboro they have problems with the in-tank pickup. I don't know how an external pump would work on a stock tank. As far as the pump's capacity, I don't know. Can you ask your trusted engine builder? |
the pick up is actually going to be cake. i already have a line in the tank that has a sping loaded lil gadget that holds the pick up tube down to the bottom of the sump on each side of the tank. im more worried about reliabilty and flow capacity. this is my dd and i dont want to be stranded.
![]() Join Date: Dec 2002
Well, you're off the right start by removing that gutless turd of a Mazda engine. I don't recall the SR fuel pump's stock flow rate but check it against that and a Z32TT, if it's within that range you should be fine.
