Old 11-26-2008, 07:04 PM   #1
deadstock40
deadstock40's Avatar
deadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of lightdeadstock40 is a glorious beacon of light
KA automatic tranny
hey guys, so on my auto s14 the check engine light came up last night at a light. i pulled the ecu n got the code 125 which is for line pressure solenoid valve.
i searched and found that the 2 pin resistor by the shock tower could be the problem but it was all plugged, but i cleaned it anyways. also, after i had the keys to the on position for 10 min or so id hear this buzz from under the car.
should i just replace the line pressure solenoid valve on the tranny ?
if so, you how hard is it to get too.
i checked the fsm ( at-145 ) and im not quite sure of how to replace it. i was sorta confused by the explosion diagram and the disassembly diagram.
deadstock40 is offline   Reply With Quote
