Old 12-01-2008, 05:14 AM   #1
snuze671
snuze671 is an unknown quantity at this point
CEL help.. throwing 4 codes (96 s14)
hey guys, my 96 240 is giving off 4 codes for the check engine light..
P0325 = knock sensor problem (bank1)
35 = key cycles since failure
P1447 = purge monitor
0 = key cycles since failure
im not too worried about the knock sensor cuz i could just replace it, but the other three is what im clueless about. what do i about the purge monitor? and what does "key cycles since failure" mean?
help, anyone..
snuze671 is offline   Reply With Quote
Old 12-01-2008, 05:45 AM   #2
cotbu
cotbu's Avatar
the purge monitor is fuel evaporation system (charcoal canister) and hoses, valve etc.
key cycles after the code is ignition cycles since the code has be stored.
And you didn't search did you
Old 12-01-2008, 06:28 AM   #3
snuze671
i tried searching the key cycles but no luck..
can't you clean the evap canister?
if so, how?
if not, then i'll have no choice but to replace.
i just need to pass smog ..
