#1 | |
![]() Join Date: Jun 2006
Heater isn't work. Brings from outside
I've searched and I know this has been posted.
I have a 95' S14. I read something about a cable that turns on the heater. I search and looked in the FSM and couldn't find anything about it. Can anyone help me on this?? I have no idea what to look for. Also I heard from a friend that I should flush my radiator since it's over 2 1/2 years old. Or could there be anything else that would cause this problem??
![]() Join Date: Dec 2002
On 1995 models only there's a cable coming off the mode door motor that actuates a valve on the firewall heater hose. Have someone operate the unit inside while you watch the cable, see if the valve is working. Could be kinked, broken, or the motor has jammed somehow.
not quite..... if its blowing but not hot could also be the blend door or cable/actuator for the blend door. If it has a water control valve instead of a blend door it could be that or something related to that system (control, wiring etc)
#5 | |
#7 |
Not always. No heat can mean a dead blend door motor, jammed linkage, faulty control unit, or other mechanical issues. Could also just have a clog in a line or the hoses on backwards at the firewall.
#8 | ||
It blow air out. Just not warm or hot air. It's cool air.
Also my car warms pretty quick. Like after 5 min of driving it's warmed up. Quote:
Anyone else chime in with a pic would be great. It's winter and foggy as hell I need my defrosters and heat!!
#9 | ||
![]() Join Date: May 2005
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
I have a similar problem as the OP. My heat doesn't work... at all. It kinda worked last year, but this year its dead. My blower doesn't always work, so I just opened the sunroof a bit to get circulation when it worked. I think my valve is stuck. Reason being that I can't turn it by hand, I can't open or close it. Am I supposed to be able to open or close it manually?
![]() Quote:
http://zilvia.net/f/sale-items/24807...-stuff-fs.html |
#11 | |
If the car warms up to operating temp, but doesn't overheat, I doubt its the thermostat.
![]() Quote:
#12 | ||
#13 | |
Okay I found it. It looks like it's work. It moved up and down. What's next??
