Old 12-02-2008, 07:43 PM   #1
dogg4217
dogg4217 will become famous soon enoughdogg4217 will become famous soon enoughdogg4217 will become famous soon enoughdogg4217 will become famous soon enough
s13 battery relocation problem, power staying on after key taken out
I have a 93 s13 se. I just finished relocating the battery due to my sr20 swap and boost pipes being in the way.
I followed this write up
Technical Articles: Low-Budget Battery Relocation
I turn the key to accessory and my power windows go down, my lights work, my ebrake and seatbelt indicator lights come on. Seems like it's working right. Well I turn the key off and pull the key out and the power is still on. I can do all the above while the key is out of the ignition. I mean it's cool and all to power my windows up and down but I know this isn't right.
So to cancel out problems, I disconnect my SR harness from the chassis harness. I disconnect the SR harness to the dash harness, so basically the SR harness is not hooked up anywhere to the other chassis harnesses. Power to the windows and lights is still there. At the stock battery location the power cable has two plugs connected to it. I disconnect these plugs and the power to the windows and lights goes off. Refer to the last pic in the link. THats the two plugs I am talking about.
What is causing my power to stay on after I take the key out?
dogg4217 is offline   Reply With Quote
Old 12-02-2008, 07:48 PM   #2
DrFtKiNg240sxy
DrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfection
your first problem is, you went on nico.
DrFtKiNg240sxy is offline   Reply With Quote
Old 12-02-2008, 07:55 PM   #3
240love
240love's Avatar
240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection
nico might be pretty lame but sometimes they got good info
240love is offline   Reply With Quote
Old 12-02-2008, 08:02 PM   #4
dogg4217
Eh nico is good for looking up things
One thing I did was I took the negative cable out and used that in the trunk to hook up the battery. Does a negative cable still need to be hooked up where the stock battery location is?
Old 12-02-2008, 10:00 PM   #5
tgd89
tgd89 is on a distinguished road
So you took the negative cable that connects the engine ground to the original battery and used it to connect the relocated battery to a ground in the trunk?
You should hook the engine ground to the chassis somewhere, and use a new cable for the trunk battery, though this is probably not your problem.
tgd89 is offline   Reply With Quote
Old 12-03-2008, 07:05 AM   #6
dogg4217
Yeah I wouldn't think a engine ground would be the problem. I am going to double check the ignition switch to make sure there is nothing wrong with it.
Old 12-03-2008, 02:19 PM   #7
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
you probably forgetting about your turbo timer. lmao. j/k.
bl3ujay07 is offline   Reply With Quote
