Old 12-10-2008, 06:51 PM   #1
FinkenS14
FinkenS14 is an unknown quantity at this point
Send a message via AIM to FinkenS14
Is It Bad
Is it not a good idea to ground shit to the valve cover bolts? Would that be a good ground??
95 S14-RB26DETT
FinkenS14 is offline   Reply With Quote
Old 12-10-2008, 06:52 PM   #2
projectRDM
projectRDM's Avatar
What is 'wud'? And why would you ground shit? More so, why would you even have shit under your hood?
FORMERLY R240NA
Old 12-10-2008, 06:53 PM   #3
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
hahahahahahaha, no its not that bad of an idea.
Slip Gypsies Blog
not sure if you realize this
Old 12-10-2008, 06:55 PM   #4
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
wud wud in the butt.
wud wud.
Old 12-10-2008, 06:57 PM   #5
FinkenS14
LMAO
Sorry guys. Serious question though. Just trying to trouble shoot a buddies car. Cranks but no spark and we had some ground on the valve cover bolts but from what hes saying the valve cover has a rubber gasket, hence defeating the purpose of grounding anything on it?
95 S14-RB26DETT
Old 12-10-2008, 07:00 PM   #6
allntrlundrgrnd
allntrlundrgrnd's Avatar
Old 12-10-2008, 07:23 PM   #7
FinkenS14
LOL, thats awesome
95 S14-RB26DETT
Old 12-10-2008, 07:38 PM   #8
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
dont grind the valve cover or set it on the ground.
bigOdom1 is offline   Reply With Quote
Old 12-12-2008, 02:46 PM   #9
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
the nut goes on the stud....the stud screws into the head... the rubber gasket for the VC or the bushings for the screws do not interrupt that path...so we can conclude you may not know how to fix his car...
ALSO
Its not a good idea if the engine isn't properly grounded. There are a few hundred better places on the chassis to ground to anyways, plus it would look better.
a working starter is a good sign that an engine has a proper ground. FYI
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 12-12-2008, 03:04 PM   #10
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
I once had a customer that asked if he can run a wire to the actual "GROUND" as in the street.
.... that was a great day
Chrischeezer is offline   Reply With Quote
Old 12-12-2008, 03:11 PM   #11
s14unimog
s14unimog's Avatar
Trader Rating: (22)
yeah we should all sport drag chains for better grounding. wow, that would be a funny story if you got pulled over.
"Sir, why are you dragging a chain...."
"uh....better ground, officer.....duh"
Old 12-12-2008, 03:15 PM   #12
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
No, it's not a good idea to ground wires to your VC. Also you should have proper grounds on your engine block, intake manifold, exhaust manifold, and cylinder head, sometimes a transmission ground if you are anal.
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 12-12-2008, 03:22 PM   #13
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
give up trying to fix cars...
what kind of car?
motor?
what is it doing??
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 12-12-2008, 03:31 PM   #14
tre4s13
tre4s13 is an unknown quantity at this point
Send a message via AIM to tre4s13 Send a message via Yahoo to tre4s13
ground to the spot where your negative cable from battery goes (right above throttle body or below? *shrug*) and there's another good spot behind the head on the driver side, there's a wire that goes from the head to firewall, those are awesome spots....but if you want a hidden look to your grounding just find a nice spot on the chassis.
tre4s13 is offline   Reply With Quote
Old 12-12-2008, 04:20 PM   #15
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
Oh and lets not forget the exhaust gound from exhaust to rear subframe
-Bart
DJ_Sunrise is offline   Reply With Quote
