Old 12-10-2008, 07:40 PM   #1
jdminspiredcd7
jdminspiredcd7 is on a distinguished road
Question Too many hoses not enough fittings!!! And vice versa (AND TRUST ME I SEARHED)
OK SO HERES MY ROBLEM....IM PUTTING A NEW TURBO ON MY CAR SO I DECIDED TO GO TOP MOUNT T3 SET UP. I BOUGHT ALL THE NECESSARY THINGS FOR IT TO WORK.......I JUST DONT KNOW WHAT GOES TO WHAT
EXAMPLE.....MBC VACUUM LINES....EXTERNAL WASTE GATE VACUUM LINES ,GAUGE LINE (AND "T")....AND A NIPPLE THAT HANGS OF THE TIP OF THE TURBO.
SO MY SET UP IS T3 TOP OUNT MANIFOLD,EXTERNAL WASTE GATE,MBC,AND BOOST GAUGE....IT MIGHT HELP
ALL THE RESEARCH I HAVE DONE IS EITHER FOR JUST ONE OR THE OTHER(JUST GAUGE,JUST WASTEGATE ETC),THEY SAY I HAVE TO "T" THIS AND "T" THAT, I TRY IT THE FORUM WAY BUT THERES NOT ENOUGH VACUUM SOURCES,I TRY IT THE WAY THAT THE INSTRUCTIONS SAY BUT THERES NOT ENOUGH LINES...OR VICE VERSA...
I KNOW SOMEONE HAS TO HAVE THE SAME SET UP...OR CLOSE TOO IT
!!!!!!!!!!!!!!PLEASE HELP I DONT WANT TO BLOW ANYTHING!!!!!!!!!!
jdminspiredcd7 is offline   Reply With Quote
Old 12-10-2008, 07:48 PM   #2
tramp_drift240
tramp_drift240's Avatar
tramp_drift240 is on a distinguished road
Send a message via AIM to tramp_drift240
CRUISE CONTROL ENGAGE!!!!!!!
sounds like you dove into a project deeper than you can swim.
tramp_drift240 is offline   Reply With Quote
Old 12-10-2008, 07:52 PM   #3
DJDANGER24
DJDANGER24's Avatar
MBC connects to anything on the intake side for vacuum purposes and the other connects to the wastegate. what nipple on the tip of the turbo are you talking about ?
DJDANGER24 is offline   Reply With Quote
Old 12-10-2008, 08:06 PM   #4
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
If you can't swim...you bound drizzal
I don't think you know or did enough searching. It shouldn't be that difficult. Most vacuum sources come from the throttle body. Turbo lines shouldn't be difficult either, just find out which is what. Oil return, coolant and what not.
CHILL WITH THE CAPS LOCK!!!! YOU DON'T HAVE TO YELL AT PEOPLE ON THIS FORUM!!!!
duffman1278 is offline   Reply With Quote
Old 12-10-2008, 08:15 PM   #5
DJDANGER24
DJDANGER24's Avatar
funny how i just searched and found everything you needed.... search a bit more and be patient, gather all the info for all the individual parts then go from there. relax...its gonna be okay.
Old 12-10-2008, 08:25 PM   #6
jdminspiredcd7
so tru....im stuck
the fitting thats on the tip of the t3/t4 turbo.right before the coupling
my bad on the cap lock thing didnt mean in any way or form to scream at you guys.but ya the oil and coolant thing i got, just the vacuum stuff with the MBC, Boost gauge,and wastegate lines.
yea i bet you searched and just got the set up for one thing right, not for all three things that i need hooked up...
Old 12-10-2008, 08:29 PM   #7
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
why dont u just combine the single threads and use the combined info?
lexus baby
5t341tH is offline   Reply With Quote
Old 12-10-2008, 08:36 PM   #8
jdminspiredcd7
trie it..... they either dont have a external wastegate,or dont have a MBC, or have a gauge but no MBC and then when i look at the MBC posts the lines are going into th place that the gauge post said....confusing? yes i know , thats why im wondering if any one has the set up i do.
Old 12-10-2008, 08:45 PM   #9
sbanzer123
sbanzer123's Avatar
sbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the rough
nipple on the turbo is a boost source that you will attach your mbc and wastegate to. take a vacume line from your wastegate to your mbc then to the nipple on your turbo. then take the t for your boost gauge and put it in between the nipple that your fuel pressure regulator goes to. so you will go fpr, t, one side of the t goes to your boost gauge and the other side goes back to the nipple on the intake mani that it came off of. hope that helps.
sbanzer123 is offline   Reply With Quote
Old 12-10-2008, 08:51 PM   #10
jdminspiredcd7
soinds like it would work...just one little problem,my external wastegate has TWO! fittings coming of it. which one goes to what?
Old 12-10-2008, 09:21 PM   #11
rc1honda
rc1honda's Avatar
rc1honda is an unknown quantity at this point
Also buy a boost manifold. That way instead of having a engine bay that spider man built, you can just use one boost line into that and run your vac sources from that.
rc1honda is offline   Reply With Quote
Old 12-10-2008, 09:26 PM   #12
jdminspiredcd7
hA ha!! spider man built...good one i thought about it for a while ......i was looking into that as well but i think that willl confuse me a tad bit more...
Old 12-11-2008, 01:19 AM   #13
Icy13
Icy13's Avatar
Icy13 will become famous soon enoughIcy13 will become famous soon enoughIcy13 will become famous soon enoughIcy13 will become famous soon enough
jgs boost block. Google and enjoy. like rc1honda said...
Icy13 is offline   Reply With Quote
Old 12-11-2008, 04:13 PM   #14
jdminspiredcd7
does any body have a diagram on how to run them....or any body have the same set up??
Old 12-11-2008, 04:31 PM   #15
Om1kron
Om1kron's Avatar
i've seen the vacuum lines posted up millions of times...
Wayne Edwards
https://om1kron.blogspot.com
Old 12-11-2008, 04:34 PM   #16
Om1kron
Om1kron's Avatar
boost vacuum lines, that's all i'm throwing you.. enter it somewhere and hit enter, tell us if you found anything. try it before you respond, that is your homework. Then tell us what problems you have AFTER YOU TRIED WHAT YOU SEARCHED FOR AND FOUND like a good boy.
Wayne Edwards
Old 12-11-2008, 09:42 PM   #17
jdminspiredcd7
............................OK.................... i searched......................and like i said before,its either one or the other........not all three things. and when i put all of them together it doesnt help, lines go into the same lines.welll
OK New Qustion.................does any one have a external waste gate, boost gauge, and MBC? if so can you tell me how you hooked up the lines?
Old 12-11-2008, 09:44 PM   #18
DJDANGER24
DJDANGER24's Avatar
thats what a T is for, so you can use it to go to 2 different places. hook everything up, take a picture and post up what you dont understand...
