Old 12-10-2008, 07:47 PM   #1
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
caster problem?
recently did my alignment on my s14, i have megan coils and im slammed, i thought my camber on my pass. side wheel was off because of bad tire wear and the wheel was more sunked in then my driver side.
turned out that the camber was good but the caster on my passenger side is off my 2degrees.
driver side 7deg caster
pass side 5deg caster
i believe 7degres is about right for our car b/c on the hunter rack it was in the green.
how do i adjust for caster? what do i need to do to correct this?
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 12-10-2008, 07:51 PM   #2
pete240
pete240 is making a name for him/her selfpete240 is making a name for him/her self
Do you have stock or aftermarket tension rods? Well seeing as you don't know how to adjust caster i'm betting you have the stock stuff which is most likely worn pretty bad if the caster specs aren't even. The stocks do not have any adjustment so you need purchase some adjustable ones like SPL V2's for example or Battle version.
SPL-Tension rods
pete240 is offline   Reply With Quote
Old 12-10-2008, 08:33 PM   #3
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
factory has no adjustments for caster. u gotta get ^^ those adjustable tension rods(aka TC rods)
lexus baby
5t341tH is offline   Reply With Quote
Old 12-10-2008, 10:33 PM   #4
wht240sx
wht240sx's Avatar
wht240sx is an unknown quantity at this point
Caster has no affect on tire wear. A caster split like that would cause a really bad pull to the side with the lower caster. make sure your coilovers
are about the same overall length. The overall length of the coilover will affect caster, and yes buy some tension rods.
wht240sx is offline   Reply With Quote
Old 12-11-2008, 12:04 AM   #5
jakerps13
jakerps13 is an unknown quantity at this point
Send a message via AIM to jakerps13
You are spot on. However an extremely worn tension rod can cause toe to change which can lead to abnormal tire wear on s chassis'.
7 degrees is fine. You can adjust simply for rubbing issues or how easily your wheel centers itself. More caster your steering wheel will want to center itself more easily, less you have to use more effort.
Lower than a pornstar's morals.
jakerps13 is offline   Reply With Quote
Old 12-10-2008, 10:47 PM   #6
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
I had the same problem. My TC rod bushing on one of my stockies was all torn and leaking and whatnot. Got some Cusco's and an alignment and I was good to go.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 12-10-2008, 11:59 PM   #7
S14DB
AFC #1
S14DB's Avatar
Park on any curbs and bend your TC rod braces? Sounds like something is bent.
Old 12-11-2008, 12:09 AM   #8
AznDrftr.
AznDrftr.'s Avatar
AznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond repute
Send a message via AIM to AznDrftr. Send a message via MSN to AznDrftr. Send a message via Yahoo to AznDrftr.
yea drivers side is like that, it goes towards me more, thus makin me rub my wiring harness, so i def need to fix that here pretty soon.
AznDrftr. is offline   Reply With Quote
Old 12-11-2008, 12:33 AM   #9
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
My TC rods are the exact same length, but my passenger side is off 1.0* (OEM w/ES inserts)
FLCA?
Bigsyke is offline   Reply With Quote
Old 12-11-2008, 04:34 PM   #10
S14DB
AFC #1
S14DB's Avatar
FLCA?
1* from each other and 0.5* out from center is within the stock spec. So if you have the stock rods you are fine.
If you get Adjustable, You want to shoot for 7*+ and less then 0.5 from each other.
Most of the problems are when people park the TC rod brackets on stop blocks and curbs. Nismo TC rod bracket fixed this for me. Second is the FLCA's being bent from hitting curbs with the wheels.
Old 12-11-2008, 01:50 AM   #11
s13Carlo
s13Carlo's Avatar
s13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura about
Send a message via AIM to s13Carlo
thats the saem thing with my car, ecept on the driver side and ive checked everything and nothing seems to be bent i was thinking it was my strut tower, still no idea what it is.
s13Carlo is offline   Reply With Quote
Old 12-11-2008, 07:57 AM   #12
jakerps13
Is your front crossmember square with the rest of the car?
Old 12-11-2008, 10:20 AM   #13
turbo2nr
turbo2nr's Avatar
well i have stock t/c rods but i do have battle version rods i havent installed yet, i guess now im going to install them, when the car was on the lift i did inspect the t/c rods and they seemed to be in good shape. im going to have to measue the crossmember/ t/c rods and see if their is a difference in lenght to determine if its is out of spec.
the coilover hights are even all around i measured the coils and i also measured form fender to lift.
my only other complaing is that i get a vibration on my steering wheel form 55-60 its wierd. im thinking its my outer tie rods ends.. wheels are new so they are mounted and balanced correctly..
i hate nyc roads...
s14 kouki ka-t
Old 12-11-2008, 10:45 AM   #14
wht240sx
wht240sx's Avatar
If none of your steering and suspension components are loose or worn
then its a tire vibration. chopped tire wear, improperly balanced tires, or internal tire seperation. My steering wheel shakes/vibrates at that same speed, im just to lazy to balance my front tires.
