Old 12-10-2008, 10:18 PM   #1
Troutman2
Troutman2 is an unknown quantity at this point
91 240SX Nissan ECU
My ECU shorted out. I am looking to buy a used one, NO. A11-B47 G1O, (27). It is a Calif. car. The used ECU has the same numbers except for the one in the bottom right corner of the green tag. Mine is OX30. What is the significance of this number? Do they need to match?
I would appreciate any help.
Thank you
Troutman2 is offline   Reply With Quote
Old 12-10-2008, 10:37 PM   #2
blackrms13
blackrms13's Avatar
stands for a 1991 KA24DE Auto ECU
and #27 is from Cali
I used have #27 and now using #29, a Non-Cali KA24DE Auto ECU
for it to work, no it dont have to match
but some minor details might be little different
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 12-10-2008, 10:45 PM   #3
180sx Fan
180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all
from what ive heard the only difference between auto and manual ecus is that the auto one does not have a speedlimiter. Never checked this myself so im not sure about this.
Originally Posted by logik23 View Post
We all have small dicks, admit it, the difference is now I can compensate for it.
180sx Fan is offline   Reply With Quote
Old 12-11-2008, 01:57 AM   #4
s13Carlo
s13Carlo's Avatar
s13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura about
Send a message via AIM to s13Carlo
yea auto ecu have to speedlimiter and im not sure but i think they are better on gas while cruising there is no big differences between any dohc oem ecu, i have a 5 speed one sitting in my garage
s13Carlo is offline   Reply With Quote
Old 12-11-2008, 04:44 AM   #5
tre4s13
tre4s13 is an unknown quantity at this point
Send a message via AIM to tre4s13 Send a message via Yahoo to tre4s13
So what exactly IS the black print's purpose??
tre4s13 is offline   Reply With Quote
Old 12-11-2008, 11:35 AM   #6
Troutman2
That was my original question. I don't think it matters.
Old 01-16-2009, 10:46 AM   #7
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
sorry to bump this but i didnt want to make a new thread, is there anywhere where i can identify dohc ecus? and is it true youll get a CEL if you run an auto ECU on a 5 speed setup?
ZenkiKid is offline   Reply With Quote
Old 01-16-2009, 11:20 AM   #8
bbejj123
bbejj123's Avatar
bbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura about
back when i had my 240 it was a 5 spd i bought an ecu from an auto at the junkyard... it has a better fuel map and has no speedlimiter allows you to rev to 7k and no stop at 115
well worth it in my opinion and my cel never came on that may have been cuz it was taken but im not completely sure but either way you might as well take yours out unless you really want it
bbejj123 is offline   Reply With Quote
Old 01-16-2009, 11:39 AM   #9
projectRDM
projectRDM's Avatar
The fuel map is NOT different on an auto ECU. You may think it was, but it's not.
On an S13 you can pretty much use any 91-94 ECU, auto or manual, Federal or California, if it's a manual chassis. Autos of course require an auto ECU.
For S14s you can use any 95-98 ECU but for 97-98 ECUs in a 95 chassis you need to repin for wires, same for swapping the other way, a 95 ECU into a 97-98 chassis.
FORMERLY R240NA
