Old 02-11-2003, 11:57 PM   #1
LOwrestling2001
LOwrestling2001 is an unknown quantity at this point
How do you all hook up your profec Bs?
Hi,
I am trying out different ways to hook up my ebc, and wondering who has most success with a certain way, or is it all the same? My first setup was:
Vacuum line from profec unit teed off of FPR along with boost gauge
Input line hooked to turbo compressor housing
Output line to the wastegate
I tried a second setup, but i'm not sure if it's better or not:
Vacuum line from unit T'eed off Input Line to Turbo compressor housing (to read boost pressure at same time, no need for unit to read vacuum)
Output line left the same at wastegate.
I figured the second configuration runs less vacuum line from the unit (coming from driverside firewall straight to near turbo compressor housing, as opposed to going around the motor to near the throttlebody).
Which do u guys think is better? All opinions and ideas appreciated. Thanks
LOwrestling2001 is offline   Reply With Quote
Old 02-12-2003, 10:07 PM   #2
wpayne
wpayne's Avatar
wpayne is an unknown quantity at this point
Man, I did this on a RB25DET like 2 years ago...it's been a while.
Lemme see, if I remember, the first one sounds like what the instructions that came with it said. Don't really worry about the extra travel the vacuum lines make, the difference is so minute it won't be detectable.
Do you have a stock actuator or do you have an aftermarket wastegate?
Too many people use cars as an extension of their PENIS and they make me sick. A car is to get you from point A to point B or for motorsports. Not revving around town at stop lights.
Check out my mods!: 50,000watt super amp and JDM lights!! Yeah right...
S13 Silvia K's I got for free (I'm in japan now)!! Woot woot!
'99 25GT-T Skyline (I don't want to list all the parts) http://welcome.to/skylinegtr
'92 240sx HB
wpayne is offline   Reply With Quote
Old 02-12-2003, 10:23 PM   #3
LOwrestling2001
stock wg
Old 02-12-2003, 10:34 PM   #4
wpayne
wpayne's Avatar
Then the first setup should work find. Good luck!
'92 240sx HB
