Old 12-19-2008, 03:16 PM   #1
chibo
chibo's Avatar
chibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfection
Send a message via AIM to chibo
S14 Heat Not Working
Alright - bone stock KA, nothing molested.
Looks like it has a new waterpump, new hoses, etc. Everything is hooked up correctly. When I turn on the heat I just get ambient air blowing at me. Probably related is that there is some temperature gauge fluctuation - when I'm engine braking the water temp dips a little, same with WOT up in the rpms.
Am I looking at a dead thermostat? Any other ideas? Thanks.
1989 S13 | 1996 S14 | 2001 E46 | 2009 ZX6R
chibo is offline   Reply With Quote
Old 12-19-2008, 03:45 PM   #2
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
What year?
If it's a '95, it has a cable operated valve on the heater hoses. Look behind the intake manifold...make sure it moves when you slide the temp control to HOT.
If it's '96-98...then you have some other problem.
The temp fluctuation is probably a loose connection at the sender...it's just a spade clip...and that gauge is pretty inaccurate.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 12-19-2008, 04:33 PM   #3
S14DB
AFC #1
S14DB's Avatar
On the OBDII S14's the valve usually fails open. It should be open, then when you start the car the valve closes. This is to keep the core purged.
Usually what fails is the mixture damper. Slide from hot to cold fast and listen to hear it travel.
Old 12-19-2008, 09:35 PM   #4
chibo
chibo's Avatar
Ding ding. Thank you guys. I had someone slide it back and forth while I watched/listened and didn't see anything move. It is a 96.
Old 12-19-2008, 09:48 PM   #5
reinvent
reinvent is an unknown quantity at this point
dumb question on the s13 , what does the hot cold switch on interior heater do to change between hot and ambient? i assume hot water always flows through heater core and the switch changed the ducting?
reinvent is offline   Reply With Quote
