Old 12-21-2008, 03:10 PM   #1
ono
ono is an unknown quantity at this point
Tranny 5-Speed HELP HELP HELP!!!
ono is offline   Reply With Quote
Old 12-21-2008, 03:35 PM   #2
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
I assume you have the SR20DET? They are always a PITA to get the tranny back onto the motor.
probably your new pilot bushing is not pushed back far enough - or you damaged it installing it - a way to tell is take the clutch alignment tool and see it it will go into the pilot bushing hole - if it wont go n the tranny input shaft will not for sure
make sure the input shaft is lined up with the clutch disk
when you get it lined up - grab it from the rear of the tranny and start wiggling it up and down while pushing inward
It will take a bit of wrestling with but it will go in - make sure you have the dowel pins on the motor lined up with the tranny holes - then get it in close enough to install the bolts and the just tighten them down in a X pattern
The SR tranny is a bit heavier than the KA - so it will wear you down
I had the same issue with my first SR tranny - then after I pulled it agin and installed it back on - It went on fairly easy - It ended up being that the new pilot bushing wasnt pushed back far enough.
Also another way to make sure your cluch disk will fit - pull the tranny off and slide the clutch disk onto the trany input shaft
LMK if you need more help
I am making you a clip from my SR20DET Swap DVD - I will post it as soon as it loads up.
JDS Performance is offline   Reply With Quote
Old 12-21-2008, 04:07 PM   #3
JDS Performance
Trader Rating: (53)
I have a video clip on my website of how to removal and install a KA tranny
its the bottom video clip - bu the top video clip is something usful to watch as well!
here is the link - give them a few minutes to load up as they a really big files;
www.240SXTECHDVDS.org Tech Page
Old 12-21-2008, 03:46 PM   #4
ono
Old 12-21-2008, 04:10 PM   #5
theronin
theronin's Avatar
theronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfection
Send a message via AIM to theronin
yeah i feel you man, it was a pita to get mine to line up. we went at it for a good 45 min before giving up. we took a 10 min rest tried it again and BAM. sucker just slid right in. lol just be patient.
Originally Posted by HalveBlue View Post
That first picture is totally bad ass.
It just screams, "Hey, I'm a fucking Christmas Tree. What are you gonna do about it?"
theronin is offline   Reply With Quote
Old 12-21-2008, 05:14 PM   #6
JDS Performance
Trader Rating: (53)
Here is the SR20DET Tranny Install Clip from my SR20DET Swap DVD;
Old 12-21-2008, 05:20 PM   #7
JDS Performance
Trader Rating: (53)
If you cant get it on after all this - then something is wrong with your stuff!
I seriously hope your trying to put the tranny on with the motor in the car as that is a huge PITA to do without a tranny jack (which most people dont have)!
I would actully pull the motor just to install the tranny - but thats just me!
Old 12-21-2008, 04:43 PM   #8
ono
Old 12-21-2008, 04:54 PM   #9
ChicagoS14
ChicagoS14's Avatar
ChicagoS14 is making a name for him/her selfChicagoS14 is making a name for him/her self
Send a message via AIM to ChicagoS14
Originally Posted by ono View Post
still no luck, anybody want to make some quick cash?
-Garrett
You have to rotate the trans and install it upside down, otherwise bellhousing wont clear trans tunnel. So in otherwords install it upside down and once its on you can rotate it. Try that it should work out.
With 2 jack stands and a trans jack I can usually do the job myself. If I had more garage space id bench the bitch on there, but my garage is cramped so a trans jack helps balance the weight.
95 240SX 1JZGTE | SC300 2JZGE daily
www.240sxguide.com
ChicagoS14 is offline   Reply With Quote
Old 12-21-2008, 04:53 PM   #10
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
I wish you weren't so far or else I'd help you for beer and pizza in return.
The way we got mine on was we had 3 ppl. 2 on the ground lifting the transmission and 1 guy managing the floor jack that we placed the transmission on. This way it was easier to lift the transmission and move it around so that it would find its way in. It's not wiggling that you need to do, but slight rotating both counter and clockwise. With this method you don't tire yourself out as much and you're able to be more patient while moving it around to get it to slide in correctly.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-21-2008, 06:16 PM   #11
ono
Old 12-21-2008, 07:22 PM   #12
JDS Performance
Trader Rating: (53)
lololol i fail, it isn't going to go on flush huh? cuz of the pressure plate right? omfg, so i put it in, as far as it'll go, with about 1/2 inch between bellhousing and engine, and then just toque it down right?
no it should go on flush - if your pilot bushing isnt back all the way it will make it near impossable for it to go all the way flush onto the motor though.
Do not try and force the bolts on or you will end up breaking them
Remove the tranny - use your clutch alginment tool - cut about 1/2" off the end of the alignment tool and stick it into the pilot bushing - then use a hammer and knock the pilot bushing all the way back - the clutch alignment tool is too long for the SR - this is why you need to cut 1/2" off the end of it.
After doing this the tranny should go on easily
Alot of people use 12mm deep well socket to knock the pilot bushihng in - but its really easy to damage it this way - the clutch alignment tool is best - because as long as it will go into the pilot bushing the tranny input shaft will too and your good to go.
