Old 02-14-2003, 08:53 PM   #1
deviousKA
deviousKA's Avatar
deviousKA is making a name for him/her selfdeviousKA is making a name for him/her self
Send a message via AIM to deviousKA
Troublesome Speedometer
ok. i have a 1990 240. my speedometer will work sometimes and sometimes not. it will (about 40% of the time) stop working and drop to zero. i took my dash apart and pulled the guages out expecting it to be similar to a d21 analog speedo, with a cable. to my surprise i find that it is an electronic needle unit. i have a crappy haynes or chilton book and i shows that unless i have a digital speedometer i should have an analog cable. ok i thought i was going to be able to repair the problem by fixing a falty cable connection as tapping on my dash seems to sometimes fix the problem. is this a common problem? anyone have a fix? im probably just going to the wrecking yard and getting a new guage cluster. maybe if i unplug it and reinstall it will work? i kinda doubt it though
deviousKA is offline   Reply With Quote
Old 02-14-2003, 09:42 PM   #2
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
Mine did the same, I just recently replaced it and know everything works fine. Only problem was I had 79k miles on the old gauges the new one was like 137k miles on it :-\ Besides that my speedo is perfect now.
ca18guy is offline   Reply With Quote
