Old 01-06-2009, 02:45 PM   #1
mystacarlo
mystacarlo is on a distinguished road
s14 Swapping comp housing turbo blades
Is it possible to swap compressor housing turbo blades on a garret GT3076R, the turbo i wanna put comp blades are chipped up and the turbine blades are perfect, and i have another turbo where the comp blades are perfect but the turbine blades are chewed up, is it possible to swap the comp housing blades?.
Ima post pix of the blades, for yawls opinion if it really matters that the comp housing blades are damaged.
mystacarlo is offline   Reply With Quote
Old 01-06-2009, 03:50 PM   #2
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
i would definitely think that the damage to the blades does matter. it could possibly throw the blades and shaft out of balance causing even further damage. whether or not the blades can be swapped or not, im not sure. i think it depends on the compressor size and possibly the maker
Old 01-06-2009, 05:01 PM   #3
slider2828
slider2828's Avatar
No entire chra must be replaced.... pretty sure of that... Email atpturbo.com
Turn and Burn!
Old 01-06-2009, 10:33 PM   #4
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
you can swap the compressor wheels, but you do want to be careful of the one that you use does't have the shaft play that caused those blades to get bent
on the downside.......i would recommend you let a turbo rebuilder do it so they can balance it. i wouldn't just slap it together unbalanced and expect it to last forever
just my .02,
great turbo tho, one of my fav's
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 01-06-2009, 10:38 PM   #5
eclipse_dsm
eclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond repute
GT3076R - Ball Bearing. You would definitely need a new CHRA. Call turbo rebuilders and they wouldn't even touch it. The moment you pull the turbine shaft off you will see those little ball bearings come fall off.
eclipse_dsm is offline   Reply With Quote
Old 01-06-2009, 10:45 PM   #6
Z U L8R
Z U L8R's Avatar
no you won't.
you hold the exhaust blade in place so it cannot spin (vice grips work well), take the 12 point nut off on the compressor wheel which is REVERSE THREADED so tighten to loosen in other words
swap the wheel and go.
i would just recommend you get it balanced, and whatever chra you're using better not be the blade bender with uber shaft play k
Dave
Old 01-06-2009, 11:02 PM   #7
eclipse_dsm
If the blades are chewed from the top, due to some thing that got sucked thru the intake then swapping wheel would be ok but there would be an issue of balance. Mostly turbo rebuilder balance the shaft with both wheels out of CHRA. Now if its chewed to the side then consider a new CHRA as that would be due to some serious shaft play. GL!
Old 01-06-2009, 11:04 PM   #8
mystacarlo
thanx guys, ima try to swap the blades, hopefully it will be easy. the turbo its self has no shaft play at all and it spins smooth as hell, if u blow on the wheels it will spin so the turbo itself is in excellent condition, but if i i do fuck it up, i spent lil or nothing on it anyway.
Old 01-06-2009, 11:25 PM   #9
Z U L8R
Z U L8R's Avatar
GT30/76R one of the best street turbo's out there
Dave
Old 01-06-2009, 11:43 PM   #10
MongolPup
MongolPup's Avatar
MongolPup is an unknown quantity at this point
God I'd love to find one cheap enough I don't care if I fuck it up lol. IMHO Fullrace's twin-scroll GT3076R kit is the holy grail of street-able SR turbo set ups.
MongolPup is offline   Reply With Quote
Old 01-07-2009, 12:05 AM   #11
mystacarlo
i bought this for 200, its good to have rich friends who dont care how much they paid for sumthing. lolol
