Old 01-08-2009, 12:59 AM   #1
vinhnumber
vinhnumber's Avatar
vinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfection
Cruise Control?
alright so I just picked up a 89 SOHC slammer. its Pretty much a virgin in everyway except for service maintance. The previous owner took it to a shop to get a clutch replaced thats pretty much it. I'm trying to figure out how to get the cruise control to work, the cruise control on button turns on, but the light in the cluster doesn't go on. So it pretty much narrows it down, what I'm asking is where should I look around the clutch and trans area? I figured it'd be something as easy as plugging something back in. I've searched this, but not really much informative pops up. Where should I look first? and where exactly is the CC stuff located Mainly clutch area.
Oh you be mad cuz I'm stylin' on ya!
vinhnumber is offline   Reply With Quote
Old 01-08-2009, 01:32 AM   #2
GSXRJJordan
GSXRJJordan's Avatar
I suggest you check the FSM for cruise control info -there's nothing around the tranny/clutch area that has anything to do with that system. It's wired into the brake relay, and the clutch relay (if your car was M/T from the factory), and all the equipment sits in the engine bay on the passenger side.
Download an FSM and educate yourself.
Old 01-08-2009, 01:38 AM   #3
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Actually, I believe the Cruise Control equipment is located on the driver side in an S13 if it's equipped with ABS. If not, then it sits in the passenger side.
But yeah, OP, FSM is your friend.
HalveBlue is offline   Reply With Quote
Old 01-08-2009, 09:59 AM   #4
projectRDM
projectRDM's Avatar
The cruise will not engage if it sees a ground from either brake or clutch cancel switches. First method to test it is to unplug both of those, one could be bad or broken. If that doesn't solve it, move on to the steering switch, the contacts on the wheel could be corroded or worn down. Next go to the vacuum pump, check for power/signal, then finally finish with the control unit.
FORMERLY R240NA
