Old 01-08-2009, 09:28 PM   #1
SleepR 240sx
SleepR 240sx's Avatar
SleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond repute
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
Bad CAS? s13 SR20det
Motor is essentially stock. Nothing that would affect the problem I'm having.
I have spark just fine however the injectors are not pulsing. Could a bad CAS cause this? Searched but didn't find anything. Thanks.
This is zilvia. We aren't nice.
Quoted For Truth
Check out the coolest new thing: toddrickkkkk.blogspot.com
SleepR 240sx is offline   Reply With Quote
Old 01-09-2009, 05:05 AM   #2
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
The ECU gets its timing/spark signal from the CAS. If your injectors arent firing but your Coil Packs are its not the CAS as the ECU must be seeing rotation to fire the coil packs.
Check your fuel pump, check your wiring as well.
Monooxide is offline   Reply With Quote
