Old 01-09-2009, 01:18 PM   #1
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
Missing and Stalling at idle.I've Spent 2,000$+trying to fix. Its Cursed HELP!
Ok so here is the deal-
After spending thousands of dollars trying to fix my SR i really need some advice on what my problem could be, I am completely out of Money, so i need to get this thing running myself.
Rundown, I'll keep it brief-
-Motor is stock redtop sr, car is 93 240sx
-Motor has never run correctly after swap
-Like the post says, Motor seems to miss-fire at idle (mechanic says its running very rich),
-In the higher RPM's, car runs smoothly, but also lacks power.
-After a drive, it will stall at idle, but then start up and and idle again (still misfires)
What has been done- (if you think its something i checked, ill check it again)
-No codes on ECU
-replaced TPS (bad)
-replaced MAF (bad)
-replaced injectors
-replaced ecu
-replaced coolant temp sensor
-replaced spark plugs (ngk iridium)
-checked for boost leaks
-checked for vaccum leaks
-checked vaccum hoses (correct hookup locations)
-checked timing
-checked grounds
-checked power and grounds on ecu plug
-checked Greddy Bov (closed all the way)
-checked turbo (for runout/ missing teeth)
-checked compression (150psi x4)
I have been to two shops, both can't figure it out, One shop hooked up a power fc and got it running pretty well like that. (should i just consider going this wrought)
The only other thing i could think of is the harness, but i dont really want throw any more money down the drain.
I will take any Ideas at all!
redsx13 is offline   Reply With Quote
Old 01-11-2009, 08:26 AM   #2
Hawaiian240
Hawaiian240's Avatar
Hawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud of
s13
If the Power FC ran the car well, I don't think it's the harness. Maybe the ECU has a bad tune or something. Are there any indications that the ECU may have been modified?
Hawaiian240 is offline   Reply With Quote
Old 01-11-2009, 11:34 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You checked how good the spark is? Could be a bad igniter chip...or going bad.
Also, spark plugs...what are they exactly and whats the gap?
CLICK HERE!!!
Old 01-11-2009, 12:26 PM   #4
S14Cuhh
S14Cuhh's Avatar
S14Cuhh is an unknown quantity at this point
Send a message via AIM to S14Cuhh
before a replaced my bad water pump..id clutch in, and the car would idle so low it would die..replaceing the waterpump and belts fixed it right up..it was a KADE , n/a setup..but your issue sounds similar
S14Cuhh is offline   Reply With Quote
Old 01-11-2009, 01:56 PM   #5
Silverstreek
Silverstreek's Avatar
Silverstreek is just really niceSilverstreek is just really niceSilverstreek is just really niceSilverstreek is just really niceSilverstreek is just really niceSilverstreek is just really niceSilverstreek is just really niceSilverstreek is just really niceSilverstreek is just really niceSilverstreek is just really nice
i don't really know anything about sr20's, but have you checked things like fuel filter, fuel pressure regulator, pcv, iacv, coil(s) (the sr's c.o.p. isn't it?), ect.
have you done a fuel system test or a vacuum test? i see you said checked for vacuum leaks, but not sure if that was just looking around for disconnected hoses or if you meant actually hooking up a vacuum gauge to the car and doing a test.
did you check fuel pressure, fuel pressure leak down, voltage at the fuel pump, ect?
Silverstreek is offline   Reply With Quote
Old 01-11-2009, 02:37 PM   #6
Hawaiian240
s13
But why would it run well with the Power FC hooked up??? Does the Power FC fix all the problems? I don't think so.
Old 01-11-2009, 03:13 PM   #7
Sileighty_85
Sileighty_85's Avatar
Have you tried swapping another SR ECU into it? If droppin in the PFC made it run good then i would lean toward your ECU being bad.
I had a similar issue once, My ECU came unbolted from the chassis and it ran rich and misfired. I replaced the plugs No change, but as soon as i grounded the ECU back to the chassis it ran fine again.
P.S. Its spelled GReddy
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-11-2009, 10:25 PM   #8
Ghost05
Ghost05 is an unknown quantity at this point
Have you checked the ignition timing? sounds like you might be off a tooth. A friend of mine had the same problem with his.
Ghost05 is offline   Reply With Quote
Old 01-13-2009, 12:48 AM   #9
redsx13
redsx13's Avatar
Ok, i have been working on this problem day and night, in finally able to take a break and use the computer.
-fliprayzin240sx, i got around to replacing that ignitor chip, but it still runs the same
-Silverstreek, those are some very good ideas, i checked the Fuel pressure regulator, but i did not check voltage at the fuelpump reason being, the car ran fine with the ka. As far as vaccum leaks, in not really sure what was done, the shop did that one.
-Hawaiian240, you hit it on the nose, the shop i brought it to said that they got it running good with the power FC, but when i herd it in person the thing still sounded like CRAP!
-Sileighty_85, GREDDY!, ya i know lol i spelled it wrong. the ecu is fine, the shop swapped in a stock working ecu and it still did the same thing.
-Ghost05, i will check the timing chain tomorrow
Thankyou for all your responeses
As well as what was mentioned above, i have also...
-checked ignitor
-checked coil packs
-checked coil pack harness
-pulled apart entire engine harness, traced backed every wire and checked with ohm meter (all good)
-had power fc tuned, it does not fix problems.
-re-checked maf
-checked fuel pressure regulator
Old 01-15-2009, 10:58 PM   #10
p4hang
p4hang is on a distinguished road
I had the same problem with my sr when i swapped it in. I checked the timing chain again and again, because in my mind it was a timing problem. Took me about two months of seriously knowing my whole car in and out. Bottom line is that it was because my CAS wasnt on correctly and it wasnt the timing chain.
Hope that helps.
p4hang is offline   Reply With Quote
Old 01-19-2009, 12:33 PM   #11
redsx13
redsx13's Avatar
*****update******
Ok, i got some free time so i decided to try some more things on my 240.
-replaced fuel pump (walbro)
-replaced injectors (440's)
-installed Power FC D-Jetro still nothing!
this car is a pain in the ass!!!!!!
Hope that helps.
well, like i said, a shop checked it out. they also said that they set the timing. maybe they missed somthing?
Old 01-19-2009, 01:01 PM   #12
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
You know when you wire in a SR20DET the check engine light does not work, you need to add a wire to get the MIL light to work.
Old 01-21-2009, 02:24 AM   #13
redsx13
redsx13's Avatar
There where no codes on the ECU, so even if it had i MIL it would not be on.
just to give you guys a better update on whats going on with the car, here is an up to date list on what i have done so far...
-No codes on ECU
-replaced TPS (bad)
-replaced MAF (bad)
-replaced injectors (370's)
-replaced ecu
-checked wiring harness (pulled apart, looked good, but did not replace)
-checked timing
-checked grounds
-checked alternator
-checkes fuel pressure regulator
-checked timing chain (just top two timing marks, not bottom)
-checked Greedy Bov (closed all the way)
-re-checked ecu (good)
-re-checked maf (good)
-checked coil packs
-checked ignitor
-checked to make sure all cylinders are fireing
-checked to make sure all cylinders getting fuel
-installed and tuned Apex-i Power FC L-jetro
-installed Power FC D-Jetro (no more maf)
**here are the symptoms i still have**
-lopey idle (very very rough, whole car shakes, it actually broke one of my new autometer gages)
-missing at idle
-low boost 5psi max
-low vacuum
-almost stalls after revving
-lack of power
and here is a strange fact, when i checked for boost leaks, there where no leaks in the piping, but alot of air did come out of PCV. (the T fitting in the valve cover)
Old 01-23-2009, 08:10 AM   #14
Tan-R
Tan-R's Avatar
Tan-R is on a distinguished road
Have you checked your altenator? i have had problems like this with my car and it seems to be something with the altenator... have it tested just a suggestion
Tan-R is offline   Reply With Quote
Old 01-23-2009, 11:58 AM   #15
redsx13
redsx13's Avatar
the shop said that they checked it, and i dont really have any battery issues. how do i check it? I cant take it off and bring it somewhere because the bolt in the tensioner bolt is really rusted on, and i dont want to go through a ton of work to pull the thing off if it is not whats doing it. cant i just start the car, pull the battery out while its running, and use a volt meter to check the output voltage of the battery? I think it should be like 14 volts of somthing like that.right?
Old 01-23-2009, 09:43 PM   #16
BustedS13
BustedS13's Avatar
you've spent two grand having a mechanic poke at your engine?
your parents must hate you
Old 01-23-2009, 10:42 PM   #17
Sileighty_85
well the only think i could think of is its gonna be Mechanical Timing you said you checked the Cams but not the crank
Maybe look into pulling the from cover off and checking the all three dots.
後輪駆動車1番
1986 SR86 - 200ish
Old 01-28-2009, 02:15 PM   #18
xcye12
xcye12 is an unknown quantity at this point
Did you check the CAM sensor?
-No codes on ECU
-replaced TPS (bad)
-replaced MAF (bad)
-replaced ecu
-checked timing
-checked grounds
-checked alternator
-checked coil packs
-checked ignitor
-missing at idle
-low boost 5psi max
-low vacuum
-lack of power
xcye12 is offline   Reply With Quote
Old 01-28-2009, 03:56 PM   #19
redsx13
redsx13's Avatar
I was told that if the cam angle sensor was bad the car wouldn't even run.
Old 01-30-2009, 09:01 AM   #20
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
not always the case. if its on its way out it can cause misfires, runing rough and whatever else symptoms from the timing being off. test with a known working one
ANVIL is offline   Reply With Quote
Old 01-31-2009, 06:44 PM   #21
sdrmiami
sdrmiami's Avatar
sdrmiami is an unknown quantity at this point
Send a message via MSN to sdrmiami
CAS will still work when bad. i recommend you replace it and im pretty sure that will fix you up. ive installed a few swaps that had a simular problem and swapped out the CAS and problem fixxed. email me if you have any questions i will be happy to help.
sdrmiami is offline   Reply With Quote
Old 02-13-2009, 01:44 AM   #22
esqueue
esqueue is an unknown quantity at this point
Are you guys serious? Will it also make it hard to time a vehicle? I have the messed up idle and the occasional stalling after after stopping. I did get a code 11 once but after a reset it never came back.
esqueue is offline   Reply With Quote
Old 02-13-2009, 08:12 PM   #23
esqueue
In my situation, the cams were off.
Old 02-13-2009, 11:06 PM   #24
redsx13
redsx13's Avatar
dude, that is soo crazy, i actually took the cap of my cas yesterday and the wheel was bent!!! I tried to bend it back, but it seems like it actually got worse, im buying a used cas as soon as i can find one, and i am also replacing the wiring harness, i will update you all soon!
does anyone know where a good place to find one is, i really dont want to shell out 300$ for a new one, and i dont have any friends withs srs that would let me barrow one.
Old 02-14-2009, 09:51 AM   #25
Locko
Locko's Avatar
Locko is an unknown quantity at this point
well man i had the same problem and it eneded up being a soldering on the sr wiring harness that got loose check my thread
http://zilvia.net/f/s-chassis/238640-sr-swap-wont-go-over-2000rpm.html
Locko is offline   Reply With Quote
Old 02-14-2009, 11:07 AM   #26
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
if you grab a new one, at least you know it'll work and won;t be a expensive peice of used...
Old 02-21-2009, 11:53 PM   #27
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
have you done a cylinder leakage test, and are you sure the timing chain isnt off one tooth. what did they fo with the pwer fc to get it to run better(as fas as tune)
georgesal is offline   Reply With Quote
Old 02-22-2009, 01:58 AM   #28
kalypso123
(ノಠ益ಠ)ノ彡
im betting on the CAS... still dont know why the standalone worked fine.
Old 02-22-2009, 08:22 AM   #29
Landers
Landers has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond repute
Just wondersing but did you get no codes or code 55? If you got nothing then something is up wih the ecu, Code 55 means no faults.
But i am betting that it is the CAS.
d-faction.com
Landers is offline   Reply With Quote
Old 02-22-2009, 10:13 PM   #30
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
Solder in a consult cable to your ecu, grab a snapon Mt2500 set it to generic vehicle, and look at what's going on
handinpants is offline   Reply With Quote
