Old 01-16-2009, 11:20 PM   #1
lolatclint
lolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud of
Send a message via AIM to lolatclint
Rough Steering..
I hit a little median on the driverside and my car is pretty slammed. checked my arms and toe none is bent but when i turn, the steering column rubs/grinds against one of the metal covers next to my turbo. im not sure whats damaged or what the possible outcomes may have been for hitting the median. could it maybe be that the steering column bent or the whole engine slightly dropped which caused the steerin column to get so close to the cover
please help
lolatclint is offline   Reply With Quote
Old 01-16-2009, 11:27 PM   #2
slider2828
slider2828's Avatar
Possible column or arm or subframe.... Take it to a alignment show and figure it out or mechanic shop.... Don't ask.... there isn't much you can measure or eye...
Turn and Burn!
Old 01-16-2009, 11:38 PM   #3
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
possible bad motor mount? my driver side mount went to shit, i couldnt accelerate hard while turning right because the steering shaft would rub up against my downpipe and it would feel really rough
smurfgcr is offline   Reply With Quote
