Old 01-17-2009, 03:32 AM   #1
illvialuver
illvialuver's Avatar
s14sr in s14 car wont shut off? need help a.s.a.p
My brother is helping a friend with a swap. the car was a s14 with s13 sr, but he blew the motor, so he bought an s14 sr and my brother put it in, its the full swap, ecu, wireharness , trans and the motor. So its in fires it ups, turn the key off to go home because the swap is finished, and the car stays on, takes the key out car stays on.
First thought is the turbo timer. So cheack the wiring to it, still stays on, unplug it and completly disconect it, still stays on.
the motor ran fine and shut off in the car it was in before,but now it wont turn off. Anyone have any clue as to what this is? Has it ever happened to anyone?
Old 01-17-2009, 03:51 AM   #2
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Ignition switch?
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 01-17-2009, 04:02 AM   #3
illvialuver
is there a way to test that? he tested the voltage on it and it was good.
Old 01-17-2009, 01:41 PM   #4
illvialuver
So I guess nobody knows about this? Did not think anyone would have a clue on here, but thought it was worth a shot.
Old 02-18-2010, 01:21 AM   #5
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
bump this thread.... very similiar problem. did you ever figure it out?
nieko is offline   Reply With Quote
Old 02-18-2010, 07:58 PM   #6
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
It could be your thermostat, you maybe need some more antifreeze,air cleaner temp sensor, or oil crank case, happened to me .... everything happens to me im knocking on wood
jdm213 is offline   Reply With Quote
Old 02-18-2010, 10:04 PM   #7
mptjimmy
mptjimmy is an unknown quantity at this point
bad wiring possibly, but ive seen bad ecu's do that.... open it up see if its burned
mptjimmy is offline   Reply With Quote
Old 02-18-2010, 10:18 PM   #8
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
3 possible things it could be. the first two have a 2% chance of being the problem.
1 the blue ecu relay is bad and not shutting off, swap the relay to check
2 the alternator has a bad diode in it and is not shutting off
but most likely the problem is in the wiring harness. the f3/m63 white dash plug by the ecu is not wired in correctly. 98% chance the problem is in the wiring. double check the wiring.
if you still can't fix it, i can repair your wiring fubarness.
easy...i'll even wire in the AC free of charge with the repair ^_^
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
