Old 01-18-2009, 03:45 AM   #1
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Safe lenghts for shorter coilover springs?
To get to the point, I've done all the common things to my coilovers to make them go as low as possible, yet I'd still like to go lower, so I've been looking at shorter springs.
The stock springs are 180.8 front, and 200.6 rear. First number being the length in mm, and the second the rate in kg.
Here is a list of available springs I could possibly use.
Front:
150.8
135.10 (too crazy?)
Rear:
180.6
180.8 (swap the fronts to the rear and save money, but the car would sit slightly higher than with the 180.6, which would bug me forever)
150.8 (too crazy?)
I'm sure I'll most likely end up going with the 150.8 front and 180.6 rear. The only thing that somewhat bothers me about this setup is that I already have a very noticeable "raked" look going on, and this will only increase it.
However, it's really tempting to do something like 135.10 front and 150.8 rear or 150.8 all around, although I'm sure those sizes are way too crazy, and I need some to talk me out of it, haha.
That's why I made this thread. What do you consider an acceptable length for shorter springs?
Is 5cm difference too much, especially since my rears are already drooped? I'm guessing the shock would most likely bottom out and blow very soon, as I'd be ramming metal into metal.
By the way, yes I acknowledge that no shorter spring is good for the coilover.
One last question.
Which companies make separately sold springs for coilovers? These are just Megans I'm looking at since my coilovers are Megan. I know there are other brands, which are also most likely more reputable, I just can't think of any right now. I'd like to see what lengths and rates are offered by other brands, maybe I'll find something more suitable.
Thanks for any info!
Old 01-18-2009, 04:34 AM   #2
Matej
Trader Rating: (39)
The Megan springs have a diameter of 62mm. I just looked up Swift springs, which are offered in 60mm, 65mm, and 70mm diameters.
I wonder if I could stuff the 60mm ones on...
Old 01-18-2009, 09:25 AM   #3
sultan
sultan's Avatar
sultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enough
my rears (single height ) have 2 inches of droop and handle great, you're running megans, just go for it. if you start noticing it bottom out just raise the perch a little.
sultan is offline   Reply With Quote
Old 01-18-2009, 03:39 PM   #4
Matej
Trader Rating: (39)
Well, that's all the convincing I needed to actually do this, haha, thanks.
Old 01-18-2009, 04:32 PM   #5
sultan
sultan's Avatar
safety is my #1 concern.
lol, i can't believe these things aren't blown yet.
Old 01-18-2009, 04:35 PM   #6
lflkajfj12123
^ lol that is crazy
Old 01-18-2009, 04:35 PM   #7
LongGrain
LongGrain's Avatar
if you buy new springs i would go with swift.
LongGrain is offline   Reply With Quote
Old 01-18-2009, 04:44 PM   #8
Matej
Trader Rating: (39)
The only thing that sucks is that I already have about 5-6cm of clearance from the ground to the cabin floor. So if I drop it another 5cm, it will be... AWESOME.
Old 01-18-2009, 05:33 PM   #9
luftrofl
luftrofl's Avatar
luftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant futureluftrofl has a brilliant future
Front:
150.8
135.10 (too crazy?)
Rear:
180.6
150.8 (too crazy?)
One last question.
You need to give out more information if you want the best answer. "Safe" is a useless term without knowing more information.
How close do you come to bottoming out with your current setup?
What is the purpose of this car? (DD, track, etc.)
Engrish is funny in Japan. In America, it's for stupid fanboys.
luftrofl is offline   Reply With Quote
Old 01-18-2009, 05:47 PM   #10
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
swift makes separate springs and doesn't RS*R? but i don't know any spec on them...
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 01-18-2009, 06:17 PM   #11
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
I have STANCE coilovers and they sell springs of all sizes and spring rates. IIRC standard is 175/200 for s13 on STANCE. I am running 150/175 on my car now. I would probably never go lower than 150 in the front.
Now is it the front that you are trying to make lower or the rear? Or are both already bottomed out? Also is this an s14 or s13?
If its a front then remove a collar and put it on the bottom or something, that will give you something. If its the rear and its an s14 then you shouldnt be running into any cant lower enough situation... If its an s13 then you can droop if its bottoming out.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 01-18-2009, 07:22 PM   #12
Matej
Trader Rating: (39)
Thanks. Stance's website doesn't seem to list the actual sizes and widths, I'll probably give them a call.
By the way it's an S13, and both bottom collars are removed already on all four corners, with the front slightly preloaded, and the rear all the way down and drooping.
Old 01-18-2009, 09:00 PM   #13
Matej
Trader Rating: (39)
What the heck fellers, I just measured and in the front my frame rails are less than 3cm off the ground. If I put even the 150's on the front, it'll be on the ground. My front strut towers are almost sitting on the tires already.
My car should look pretty low, right?
Why doesn't it look as low as some other S13's? I want to scrape my side steps on the ground and make pedestrians itchy.
In the rear the frame rails are about 5cm off the ground, so I'll probably just get the 180.6 for the rear. That will make the front bumper sit higher though.
Golly jee, maybe I just need lower aero...
Old 01-18-2009, 09:10 PM   #14
ericcastro
ericcastro's Avatar
is there a pic of your car??
and yes, everyone uses aero.
thats a no brainer dude.
c'mon.
Old 01-18-2009, 09:11 PM   #15
Matej
Trader Rating: (39)
c'mon.
Skyscraper.
Old 01-18-2009, 09:22 PM   #16
ericcastro
ericcastro's Avatar
LMAO!!
dude, your car is plenty low!!
what size rims??
If you could tuck those rims.........
you would have to have then adjust the actual sleeve of the coil over so the wheels and the arms hook on up the sleeve more.
or look at what other cars have short springs in the same diameter and strength. just call em up and ask??
or cut a coil off
can you find shocks that are shorter than the onse you have that will work??
maybe a mild modification to them, like weld on a different mounting spot?
I think you are along the lines of machine and welding work to get lower.
Or, try your luck at fiber glass work and extend teh bottom of that kit another 1"
Besides the "sleepy eyes" making it look like the car is broke, shit looks really good.
love the rims.
I just just got rid of the knock off of that kit.
Old 01-18-2009, 09:52 PM   #17
lflkajfj12123
sleeepy eyes are wiccckeed
i think mercer had a similar problem with this with the knockoff uras
real uras looks lower?? idk
Old 01-18-2009, 10:17 PM   #18
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
Get smaller tires? That way no clearance issue and it'll drop some. I'm guessing this is a hard parker and you don't have aftermarket LCAs? I think other cars look lower because they rock old 15 and 16s and those are what 18s?
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 01-18-2009, 10:45 PM   #19
YoungGun
YoungGun's Avatar
Fuck your megans dude.
I hate you.
I want some of those shorter sprangs.
YoungGun is offline   Reply With Quote
Old 01-19-2009, 01:31 AM   #20
lflkajfj12123
uhm
PLEASE TELL ME WHO HAS AFTERMARKET LCA'S HERE
Old 01-19-2009, 01:39 AM   #21
Sti_Guy
Sti_Guy is an unknown quantity at this point
Skyscraper.
wow. that car is beautiful
Sti_Guy is offline   Reply With Quote
Old 01-19-2009, 09:45 AM   #22
98koukile
98koukile's Avatar
uhm
Should I really make a list or do you already know? What I meant was, this car has no performance function so my recommendation doesn't account for proper suspension geometry
Old 01-19-2009, 11:36 AM   #23
240sxaddict
240sxaddict is making a name for him/her self240sxaddict is making a name for him/her self
Have you removed the coil over top mounts and bolted them on upside down yet?
240sxaddict is offline   Reply With Quote
Old 01-19-2009, 03:29 PM   #24
slo_slideways
slo_slideways's Avatar
slo_slideways is an unknown quantity at this point
Just an FYI, there is a shop that is selling a bunch of coilover springs from Stance coilovers that were swapped out with custom spring rates. So they got a bunch of coilover spring replacements for dirt cheap.
Ranging from 4k up to like 12k I beleive? And you can pick different lengths.
I just bought a pair for my fronts in 9k and total was just over $40.00 with tax and shipping... Worth checking out at least.
A little off sunject, but not much... Anybody know what the spring length is on Ground Control coilover springs for the front on an S13?
4k-9k
eBay Motors: STANCE coilover springs 4k 5k 6k 7k 8k 9k (item 220344453512 end time Jan-23-09 16:35:25 PST)
10,11, 12k
eBay Motors: STANCE coilover springs 10k 11k 12k (item 220344453736 end time Jan-20-09 16:36:06 PST)
Worth a lil look anyway!
slo_slideways is offline   Reply With Quote
Old 01-19-2009, 03:31 PM   #25
slider2828
slider2828's Avatar
I really looked at those stance springs, but man, I will pass.... Rather get something really linear, well its for the track so.... eh something good...
Turn and Burn!
Old 01-19-2009, 03:55 PM   #26
Matej
Trader Rating: (39)
4k-9k
10,11, 12k
Dude if this was preschool I would totally share my crayons with you!
Old 01-19-2009, 04:07 PM   #27
lflkajfj12123
yes i want a list
Old 01-19-2009, 04:16 PM   #28
Matej
Trader Rating: (39)
Stance owners, can you please tell me if the Stance springs have the rates marked anywhere on them?
I know most coilover springs have them written on the coils in white, but I looked at some pictures of Stances and didn't see anything on any of them.
I want to order a few different pairs and experiment, but I don't know how I'll tell them apart, haha.
Old 01-19-2009, 08:31 PM   #29
superJoy
superJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of light
The springs on my GR+ don't have any spring rates marked on them. Maybe ask the eBay seller if they can label them for you so you don't have any mix-ups?
superJoy is offline   Reply With Quote
Old 01-20-2009, 01:35 AM   #30
Matej
Trader Rating: (39)
Well, I did some very precise measuring, and came up with results indicating that in the front my frame rails are 31mm off the ground, while in the rear they are 45mm off the ground.
I ended up ordering just the 175.8 springs for the front, and I will swap the current 180.8 fronts to the rear.
Using very advanced mathematics, taking into account the way the frame rails pivot around the center of the axels, the front should be lowered to 26mm, while the rear, even though 20mm shorter, but taking into consideration the higher spring rate, the gravitational pull of the moon, and the velocity of the projectile, will be lowered to approximately 27mm.
Also, the stiff rear suspension will automatically render me the title of DK.
