Old 01-18-2009, 10:52 AM   #1
bigboto_boy
bigboto_boy is an unknown quantity at this point
HELPPP car runs funny
im in serious need of help im a noob in nissan and my car started to run like shit yesterday ok so heres how my car runs first of all it sounds like a subie bupbupbupbup like that than it bogs like the rpm sputters and it is reallllyy slow like it would take 10 sec just to reach 3k rpm pls i need help
my freind said it sounds like a blown head but idk i HOPE its not !!!!
and my other freind said the timing is a lil off
idk man it sounds like a subie and runs like a fat dude having a asthma attack fuck
before all this happend my car ran fine ! nothing but the normal chain clicking
bigboto_boy is offline   Reply With Quote
Old 01-18-2009, 11:02 AM   #2
alzahakar
alzahakar's Avatar
alzahakar has a little shameless behavior in the past
Check your injectors. From the sound of it, you might have a dead one.
alzahakar is offline   Reply With Quote
Old 01-18-2009, 11:18 AM   #3
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Check Injectors, Distributor rotor, MAF.
My brother's KA had a broken distributor rotor(bolt came loose, snapped the rotor into pieces).
So, it made it sound like a Subbie.
-Jspec-
Instagram/CrimsonRockett
Old 01-18-2009, 11:19 AM   #4
bigboto_boy
did it run like mine ?
Old 01-18-2009, 11:54 AM   #5
bigboto_boy
it sounds pretty much like this YouTube - engine is pissing me off
Old 01-18-2009, 11:58 AM   #6
worangejuice
worangejuice's Avatar
worangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond repute
The 2 times that happened on my 240's it was a bad injector. search bad inector, test, fix,beer, pat on back
http://i13.photobucket.com/albums/a253/worangejuice/sig-3.jpg
worangejuice is offline   Reply With Quote
Old 01-18-2009, 12:02 PM   #7
bigboto_boy
ok thanks ill have it checked out from my homie
Old 01-18-2009, 04:03 PM   #8
bigboto_boy
anymore ideas ?
Old 01-18-2009, 04:43 PM   #9
alzahakar
alzahakar's Avatar
Have you checked everything that was suggested to rule it out? If so, how did everything check out?
Old 01-18-2009, 06:17 PM   #10
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
Yea at times mine does this as well. But it only happens to mine after going through 1st thru 3rd gear pulls and then it starts to bog. It takes about a minute before it runs normal again.
w0nderbr3ad is offline   Reply With Quote
Old 01-19-2009, 04:30 PM   #11
bigboto_boy
nah not yet idk what to buy do i buy all 4 injectors ?
Old 01-19-2009, 05:14 PM   #12
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
unplug one of the injectors, start the car... do this with each of your injectors (replugging-in the one you unplugged before your next one) and see which one, when unplugged, makes your car run the best. this injector would be your bad one
replace it. no need to buy all 4
slothonaleash is offline   Reply With Quote
Old 01-19-2009, 07:46 PM   #13
bigboto_boy
is that how u do it ? if so ima do it right now
run the best or worst ?
oh yah one more ??? isnt it a sign of a bad injector if u smell alot of gas coming out of the exhuast like its really bad
Old 01-19-2009, 09:23 PM   #14
bigboto_boy
check the injectors number is bad doesnt effect the idle at all the rest they bog and eventually die pulled the wires the number 2 cyl doesnt effect the idle either the rest does
Old 01-19-2009, 10:46 PM   #15
alzahakar
alzahakar's Avatar
See? Dead injectors. Replace em and you should be good.
Old 01-19-2009, 11:49 PM   #16
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
What year is it again? How many miles on the motor?? Any Check Engine Light on the dash?? Have you done any servicing to the motor recently?? Oil change, add fluids, fill up with gas.... anything??....Before you go start replacing anything you must first go thru the Checklist of Things To Check before you start throwing money away.
Your problem could be something like bad gas from the gas station, (very rare - but it does happen....another possibility is a pissed off girlfriend & something poured in the gas tank). Or it could be something like a vacuum line came off, or broke, or melted....a cheap & easy fix. It could also be a bad electrical connection or worn ground wire, a dying Mass Air Flow Sensor, a defective fuel pressure regulator...which CAN mislead people into thinking a fuel injector could have gone bad.
The best way to learn about your car and save yourself some money is to use the SEARCH function here on Zilvia.net & find a Factory Service Manual for your car. Download the FSM & read up on how to use your car's ECM / ECU (engine control module - the brain of your motor) to diagnose your engine problems. It's not always the answer, but it often points you in the right direction. If you can get your hands on a FSM and read the Diagnostic Trouble Code(s) that your engine is "kicking" & read them off your car, then we will have an idea as to where to start.
If you aren't able to locate an FSM, then go to Kragen or Autozone & have them read the codes off your car for you. Last time I checked they would do it for you for free. Once you do, post them here & we'll try to help you out.
Hope this helps...good luck!!
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 01-20-2009, 01:42 AM   #17
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
Before you go and replace that injector it could be other things.
check to see if your car is even sparking at that cylinder.(check this by taking out the plug from your dead cylinder while still keeping it attached to your plug wire, and then touch it to a ground source. If it sparks consistantly you know you have spark in that cylinder)at the same time pull off your cap and look at the cap and rotor to see if its in good shape with no carbon tracking or cracks
next if that works go ahead and test for power to your injector wires. to do this you can get a volt meter. touch one side to ground and the other side to the red wire on the injector clip (its one of 2 wires, 1 is constant and the other is pulsating) if you have constant power, 'red', and the other wire is pulsating (i think it was from 0-12 volts) then you know there is power and a pulse.
so if there is power and pulse you most likely have a bad connection at the harness or most likely your injector is clogged
if you have constant power and no pulse you can jump the pulse wire from a good cylinder to that bad cylinder and if you notice the car running differently at all, you know you have no pulse.
if you dont have constant power then jump the constant from another injector and see if it fires, if it runs any differently then thats your problem.
in the instance that you do not have a pulse go ahead and pull apart your kick panel on the passenger side and take the harness off your ecu. after doing this get your volt meter and check for continuity between the prongs on your harness and the pulse wire on your injector (this is trial and error)
so if you have continuity u know there is no break in your wire.
if your at this step with continuity from your injector to your ecm, you know that you have a bad ecm.
this happened to me. hope this helps
supreme_1 is offline   Reply With Quote
Old 01-20-2009, 03:28 PM   #18
bigboto_boy
dang dont know how to do any of these told u man i just got into nissans like a month ago but ima go ahead and replace the injector see if that works if not ima have a mechanic check it out thanks tho oh yah no check lights neither
Old 01-20-2009, 04:27 PM   #19
bigboto_boy
YAHHH BOYYY replaced the fuel injector and tried it out same shit but i went to check the engine and i forgot to plug in the wire after i plugged it in like magic back to normal
THANKS GUYS FOR UR HELP ZILVIA FTW
Old 11-29-2009, 11:08 AM   #20
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
ima do this shet righttt!!! NOW!
Old 11-29-2009, 11:17 AM   #21
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
^ we didnt need to know you are gonna do this shit right now, and you didnt need to bump a 1 year old thread... just a thought...
Ceepo is offline   Reply With Quote
