Old 01-30-2009, 10:06 AM   #1
articdragon192
articdragon192's Avatar
Tire PSI for Drifting
Just wondering what psi everyone runs for drifting at the track. Figured this might help get newbies started on some sort of car set up and possible have some other intermediate drivers try something new and learn something from it.
Please post up tire size, PSI used, and around how much wheel HP you're running. If you're on a stock motor, just say that. I'll start off
Front:
255/35-18
32 psi cold
Rear:
245/40-17
45 psi cold
Around 195 whp.
Might play with the psi a bit more though.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 01-30-2009, 10:16 AM   #2
lechu84
lechu84's Avatar
lechu84 is a jewel in the roughlechu84 is a jewel in the roughlechu84 is a jewel in the roughlechu84 is a jewel in the roughlechu84 is a jewel in the roughlechu84 is a jewel in the roughlechu84 is a jewel in the rough
i like this idea.
when i was running my SOHC i was running:
front: Falken ziex ze 195/50/15 PSI=32
Rear: Falken ziex ze 205/50/15 PSI=55-60
DOHC:
front: Falken ziex ze 195/50/15 PSI=28-32
Rear: Falken ziex ze 205/50/15 PSI=40
lechu84 is offline   Reply With Quote
Old 01-30-2009, 10:17 AM   #3
Dousan_PG
Dousan_PG's Avatar
i run 40 to 60 psi
ive run 90 psi
front are usually around 30some no more then 36 hot on AD07
feddies are same because they suck dick
maxxis z1 drift can handle a 50-60psi no problem at all
federal rsr did 90 all day and died of natural causes
re01r run a 40 range
ad07 rear run a 40 range
all tires in rear are in a 245-275/18 sizes.
Aaron
Pink GodziRa
Old 01-30-2009, 10:19 AM   #4
CityTireOnline.com
CityTireOnline.com's Avatar
Trader Rating: (28)
CityTireOnline.com is close to perfectionCityTireOnline.com is close to perfectionCityTireOnline.com is close to perfectionCityTireOnline.com is close to perfectionCityTireOnline.com is close to perfectionCityTireOnline.com is close to perfectionCityTireOnline.com is close to perfectionCityTireOnline.com is close to perfectionCityTireOnline.com is close to perfectionCityTireOnline.com is close to perfectionCityTireOnline.com is close to perfection
Feedback Score: 28 reviews
Send a message via AIM to CityTireOnline.com
PSI is very hard to dtermine. Many factors are involved. Track surface, temperature, Car setup, Tire Model, and the level of traction that a particular tire gives throughout the life of the tire.
Always good to start off about 5 psi that what is recommended for the tire, and then play with it throughout the track day.
Mostly its less pressure if you are not gripping well.
More pressure if its gripping too much.
CityTireOnline.com is offline   Reply With Quote
Old 01-30-2009, 11:08 AM   #5
YoungGun
YoungGun's Avatar
Front
215/40/17 Federal 595 on 17x9.5 32 psi cold
Rear
215/40/17 Nexen 3000 on 17x9.5 37 psi cold
pretty much stock sr.
YoungGun is offline   Reply With Quote
Old 01-30-2009, 11:15 AM   #6
aoiken3
aoiken3's Avatar
aoiken3 is an unknown quantity at this point
stockish kade
front:
215/45/17 30psi
rear:
215/45/17 38ish
soon be 235......gotta play w/ the settings some more....
おれのシルビア大好きだよ!!!
aoiken3 is offline   Reply With Quote
Old 01-30-2009, 11:18 AM   #7
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
stock KA
front 215/40-17 usually around 35psi
rear 214/45-17 usually around 40psi.
I usually don't check the pressures...I only have a tiny little gauge that sucks and is hard to maneuver between the spokes.
http://bhworld.wordpress.com/
Old 01-30-2009, 11:52 AM   #8
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
I always carry a tire pressure gauge with relieve valve in the car.
235/40R17 AD07 35-40 psi
235/40R18 595, RSR 30 psi
Stock SR w/ S15 turbo stock boost and FMIC
Will be trying out the Maxxis Victras soon.
Old 01-30-2009, 11:53 AM   #9
dino6192
dino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond repute
-stock sr20det redtop-
front- 215/45/17 @ 28-30 PSI
rear-225/45/17 @ 38-42 PSI
(9" wide rims)FEDERAL 595's
but it DEFINETLY depends on the track, surface (smooth, rough or dirty), track temps and the track speed as well!
I have a mini air compressor that I bring with so I can adjust through the day if needed. (One one the best parts I ever bought for my car!)
Tsuiso.Style @ Instagram
dino6192 is offline   Reply With Quote
Old 01-30-2009, 11:55 AM   #10
Flipzide
Flipzide's Avatar
Flipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfection
back when i was using an s13 w/ falken ziex 912s,
Stock SOHC
F/R 205/50/15 40 PSI cold
Currently on my s14 w/ Federal 595s,
Redtop SR w/ boltons
F/R 215/40/17 35 PSI cold. I usually try to aim for 40-45 hot.
D-Street.net | bcuison.wordpress.com
Flipzide is offline   Reply With Quote
Old 01-30-2009, 02:02 PM   #11
SUPERSTAR
SUPERSTAR's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
STOCK SR
fronts-2055016 Dunlop Z1 star specs at 35pis cold and the take down no lower than 28psi, depends how car feels.
rears- 2055016 GoodYear Eagle F1 at 40psi cold and no lower than 32psi
But it depends on tire I use, when I run Nexen on rear I put at 32psi cold so I still have grip.
"ARE YOU ONE'EM SKID RACERS?"
Old 01-30-2009, 02:08 PM   #12
Jdotsturn
Jdotsturn's Avatar
Jdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond repute
Send a message via AIM to Jdotsturn
Stock SR 10lbs boost
F: 235/40/17 30psi
R: 235/40/17 35psi
Federal 595
i dont really know whats best though.
Jdotsturn is offline   Reply With Quote
Old 01-30-2009, 02:11 PM   #13
newblood
newblood's Avatar
newblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond reputenewblood has a reputation beyond repute
Send a message via AIM to newblood Send a message via MSN to newblood
stockish rb25
F: 215/40/17 federal 595 32psi (cold)
R: 235/40/17 federal 595 35psi (cold)
street drifter 9000!
newblood is offline   Reply With Quote
Old 01-30-2009, 02:29 PM   #14
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
I drove JXN's car last event and he has a stock black-top sr
don't know front but they were federal ss-595
rear nexen n3000 235-40-17 with 40 lbs of air cold and they spun great.
All day I used like half the tyre and they spun awesomely
wow-thats-a-cool-car is offline   Reply With Quote
Old 01-30-2009, 02:36 PM   #15
Sonic Motor
www.SonicMotor.com
Sonic Motor's Avatar
Trader Rating: (113)
Sonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfection
Feedback Score: 113 reviews
Send a message via AIM to Sonic Motor
JXN's car aka devil's silvia(666):
stock sr
Federal 595
F: 235/40/17 30-32psi
R: 235/40/17 40-42psi <-- good smoke
Or
Nexens - cuz its free(wow-thats-a-cool-car)
R: 235/40/17 40psi
Nexens last forever, but dont grip for a dam. Good for beginners(like devin/wow-thats-a-cool-car) I suppose.
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK )
Sonic Motor is offline   Reply With Quote
Old 01-30-2009, 02:48 PM   #16
charlie321
charlie321's Avatar
charlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfection
Send a message via AIM to charlie321 Send a message via MSN to charlie321
Stock Single Cam KA24
WSIR Balcony
Fronts:
-Dunlop Direzza Star Spec Z1's
-195/55/R15
-35 PSI
Rear:
-Nitto NT450's
-195/50/R15
-45 PSI
charlie321 is offline   Reply With Quote
Old 01-30-2009, 02:49 PM   #17
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
mostly stock S14 SR
Front
Falken Azenis RT615
235/40/17
32 PSI hot
Rear
Federal SS595
235/40/17
34-36 PSI hot
khilgers is offline   Reply With Quote
Old 01-31-2009, 02:07 AM   #18
94cc0rd
94cc0rd's Avatar
stock KA
front
falken rt615 235/40/17
35-37psi cold
rear
federal ss595 205/50/16
whatever the guy at city tire put in it
i think around 38-40psi cold
I had trouble initiating on balcony using a 3rd gear clutch kick ...
At the beginning of the day I was using some 205/55/16 BST radial tires at like 25-28psi (forgot to put air in after they sat in my garage) and I had no problems initiating but once I switched to my new pair of ss595s, I started having trouble and understeering.
I should've tried upping the tire pressure in the rear to 45+
94cc0rd is offline   Reply With Quote
Old 01-31-2009, 02:31 AM   #19
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
kat. est 200whp
Front
yoko s.drive 225/35-17 30psi cold
rear
yoko s.drive 235/40-18 40psi cold.
im no experienced driver, but from what little experience i do have, thats what worked.
Marcus is offline   Reply With Quote
Old 01-31-2009, 02:52 AM   #20
DoriSaruMark
DoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really niceDoriSaruMark is just really nice
Stock KADE
Kumho Ecsta SPT
225/45/17
Front 35 psi cold
Rear 70 psi cold
KA-T 249 wrhp
Federal 595
225/45/17
Front 35 psi cold
rear 45 psi cold
DoriSaruMark is offline   Reply With Quote
Old 01-31-2009, 03:04 AM   #21
MisawaJason
MisawaJason's Avatar
MisawaJason is an unknown quantity at this point
wow, after reading this thread I guess I'm going to have to step my game up this drift season. I neglect to adjust my tire pressures. Normally I just throw on the tire on the tire machine, and after sealing the bead I put them at 32ish lbs and throw them in the car. Good info
MisawaJason is offline   Reply With Quote
Old 01-31-2009, 03:05 AM   #22
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
federal rear- 28psi cold
nexens rear-25psi cold
on stockish sr setup (270hp)
Grenade180sx is offline   Reply With Quote
Old 01-31-2009, 08:29 AM   #23
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
stock ka24de (125 hp)
When I had dunlops:
Fronts:
235/40/17 fm901 - 32 psi
235/40/17 direzza z1 - 36 psi (super grippy)
Rears:
205/50/16 direzza dz101 - 50-70 psi (only at balcony just to make smoke and make it seem like I have an SR)
- 35 - 40 psi (on rough surface like el toro, Camarillo airport)
225/45/17 - sp sport maxx- 35 psi (horse thief mile)
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 01-31-2009, 10:27 AM   #24
Teddy
Teddy's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
Stock SR20DET
Front:
Dunlop Direzza DZ101 215/40R17
35psi HOT
Rear:
Nexen N3000 215/40R17
35-40psi HOT
www.realize-jp.net
Old 01-31-2009, 02:08 PM   #25
ericcastro
ericcastro's Avatar
Stock SOHC
fronts are whatever tire, at stock pressure, 15-50-205
rears. Used tires, stock pressure, 15-50-195 on steelies. with Used tires, they are slick enough.
Running fed 535's, 205 -15 -50, I ran 40lbs
Old 02-01-2009, 12:31 PM   #26
hitman
hitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfection
Send a message via AIM to hitman
i run 25 psi rear so my tires last longer, 300hp, federals
driftparty.com
hitman is offline   Reply With Quote
Old 02-01-2009, 01:17 PM   #27
nolandavid
nolandavid's Avatar
nolandavid is an unknown quantity at this point
Send a message via Yahoo to nolandavid
stock ka
front 205/50/16 40psi
rear 205/45/16 60/70psi it's like drifting on glass.
nolandavid is offline   Reply With Quote
Old 02-10-2009, 09:19 PM   #28
kris
kris's Avatar
kris is an unknown quantity at this point
SR about 350whp
front 225/45-17 bridgestone re050a pole position 35 psi
rear 235/40-18 feddies 40 psi some times run various bridgestone tires in the 225-255 range in a 17 also about 40 psi
i generally run about 35-40psi hot in the rear no matter the tire being used seems to work the best for me
kris is offline   Reply With Quote
Old 02-11-2009, 10:44 PM   #29
fckillerbee
fckillerbee's Avatar
Stock KA24DE. I usually run a 215/40/17 usually R compound for control. about 30 psi.
Rear, 215/50/16 federal 595ss, nexen 2000/3000 series, nankang (gay tires), and now some falkens. In the rear it is always about 40 psi. federals at 50 cause they grip new.
Run federals backwards for KA, they last all day, and don't grip as much. Tire pressure and grip is the most important in my book! Every time I test a car, that's the first thing I ask.
Old 02-11-2009, 10:47 PM   #30
fckillerbee
When I drove jxn's car (S13 SR), it was 55 psi in the rear...i was able to keep that car sliding no matter what, but it was harder to control.
FC'S (chows 250whp) usually have to have bigger tires less psi to grip...they just dont grip very well. for the front...really didn't matter.. about 35 psi so the car doesn't grip more in the front.
