Old 02-27-2003, 09:48 AM   #1
Speedfreak
Speedfreak is an unknown quantity at this point
tire sizes
Will a 235/40/17 fit on a 17x7 inch rim?
Speedfreak is offline   Reply With Quote
Old 02-27-2003, 10:23 AM   #2
Tubed4evr
Tubed4evr is an unknown quantity at this point
Post
I know it will fit on a 7.5in wide rim check it out. Look at the 2nd paragraph below the chart. So if BMW thinks it's good enough to run on the M3 then it should be just fine on my wheels. I think I just found my next tire size
Tubed4evr is offline   Reply With Quote
Old 02-27-2003, 09:19 PM   #3
orange-grey
orange-grey is an unknown quantity at this point
Even if it does fit, that doesn't mean you should try. When you mount a wider tire on a skinnier wheel it causes the sidewalls to fold inward towards the bead. When you throw the car into a corner, the tire has to actually move laterally on the wheel before the outer sidewall begins to stretch and transfer the "grip" from the contact patch to the wheel and then the suspension. This makes the car feel unresponsive and sloppy. If you run a skinny tire like a 195 (i.e. "drift style") the sidewalls are effectively pre-streched so response is insanely immediate, but grip is ultimately compromised with the skinnier tire. A good compromise would be a 215/45, which would give a good balance of grip and response. And if you're worried about drag racing, I would think more about getting a soft tire compound since you're effectively only running on the inner half of the tire anyway.
orange-grey is offline   Reply With Quote
