Old 02-11-2009, 01:40 AM   #1
Slacker_221
Slacker_221 is an unknown quantity at this point
overheated...
Ok i have a stock 1993 240sx hatch and it suddenly overheated and i think it blew the head gasket and more becuase it wont start back up and only has about 65 lbs of compression. i checked everything else, ignition, fuel, timing, everything else works fine but im wondring if 65lbs of compression sounds like piston rings too? Please HELP!
Slacker_221 is offline   Reply With Quote
Old 02-11-2009, 01:45 AM   #2
!Zar!
!Zar!'s Avatar
Blown headgasket.
Warped head; might also be cracked.
Low compression has to do with the motor not sealing. So compression isn't escaping between the piston rings, it's escaping from the head.
Old 02-11-2009, 02:37 AM   #3
Slacker_221
ok soo it might just be a head gasket? Do these motors usually have such low compression when the head gasket blows?
Old 02-11-2009, 08:53 AM   #4
¹²³Klan™
¹²³Klan™ is an unknown quantity at this point
what does your oil look like?
¹²³Klan™ is offline   Reply With Quote
Old 02-11-2009, 10:57 AM   #5
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
I am in the same boat as you exept I have a modified sr20 pushin 350. I think what happen is the motor leaned out from a tune I got. What is interesting is I didnt get a overheat at all but it did all of a sudden die. It must have been the heat produced in both our motors that made compression drop so bad.
One thing someone told me was it would be hard for all of a sudden all piston rings to go bad at once so it is most likely the head gasket or head. Can you let me know what it was when you take it apart?
Thats what I said
moses is offline   Reply With Quote
Old 02-11-2009, 01:46 PM   #6
Slacker_221
The oil is little milky with the water, and i can see some condensation in the valve cover.
Is it worth it to try and put a new head gasket in andsee if that works or does the motor sound fried?
Also if it is the head, will a sr20de(not det) head fit on a ka24de? if it does i know it will give alot more compression...
Old 02-11-2009, 01:50 PM   #7
sillydrift
sillydrift's Avatar
sillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond repute
Send a message via AIM to sillydrift
The water is getting in your oil due to your headgasket not sealing properly. Like the others said you can replace the head gasket but make sure the block or the head is not warped, or else you are still going to have issues with the head gasket sealing properly
sillydrift is offline   Reply With Quote
Old 02-11-2009, 03:56 PM   #8
Slacker_221
Ok thanx alot guys, i will try taking the head off and take a look at everything and see if anything os warped or cracked. If you have any more info please let me know! - Thanx
Old 02-11-2009, 04:31 PM   #9
!Zar!
!Zar!'s Avatar
There isn't really an if.
9/10 your head is warped.
You need to take the head to a machine shop.
Old 02-11-2009, 07:09 PM   #10
¹²³Klan™
milky oil is headgasketo.
ive had 3 cars with it already =(
Old 02-11-2009, 07:42 PM   #11
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
noob statement thread lol
but no only a KA24DE head works on a KA24DE. But nice try lol
wow-thats-a-cool-car is offline   Reply With Quote
Old 02-11-2009, 08:57 PM   #12
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
before you jsut go and rip it apart, why dont you do a leak down test. dont automatically take it to the machine shop to get it milled, get a straight edge and check for clearence. i believe its .001 which is safe if using a stock headgasket
supreme_1 is offline   Reply With Quote
Old 02-12-2009, 05:18 AM   #13
¹²³Klan™
why dont you just buy a new engine?
not worth the time for a ka24de.
Old 02-12-2009, 08:34 PM   #14
Slacker_221
Yeah noob with these nissan motors, I've been a Honda guy and the heads on Hondas are interchangable...
Old 02-12-2009, 08:52 PM   #15
bigboto_boy
bigboto_boy is an unknown quantity at this point
amen to that haha i am a honda guy myself and basically honda parts can fit on any honda part lol
all heads are interchangeable in hondas but b's have to go into b's and d's have to go into d series block same shit with the k series
i know honda inside in out and im still learning about nissan
back on topic just get a whole new motor !!!
bigboto_boy is offline   Reply With Quote
Old 02-12-2009, 09:00 PM   #16
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
you are holding the gas pedal down when you are checking the compression right?
georgesal is offline   Reply With Quote
Old 02-12-2009, 09:21 PM   #17
joeapple8
joeapple8's Avatar
Trader Rating: (32)
joeapple8 is an unknown quantity at this point
Feedback Score: 32 reviews
same here, haha still tryna figure out my nissan here as well, as for your blown head gasket, most likely your head is warped/cracked, Id just buy a new engine if I had the money..
joeapple8 is offline   Reply With Quote
Old 02-12-2009, 10:10 PM   #18
Slacker_221
yeah that's a problem is I don't have money for a new one, unless some one know of or has one cheap? And no I wasn't holding the throttle open when I did the compression test, that would give a more unacurate reading right?
Old 02-13-2009, 12:22 AM   #19
JDMB0iKT
JDMB0iKT's Avatar
JDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfection
Send a message via AIM to JDMB0iKT
I'm in the same boat as you, my head gasket blew on me. I'm getting the engine rebuilt right now though. But yeah, chocolate milky oil = blow headgasket. If I were you and I had the money, I would just get a new motor. Maybe a SR20DET?
Instagram
JDMB0iKT is offline   Reply With Quote
Old 02-13-2009, 03:54 AM   #20
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Why the fuck are you idiots suggesting he gets another fucking engine? Its a blown headgasket, not a fucking rod thru the block. Take the head off and get the head checked and cleaned. Get some aftermarket HG and call it a day....
CLICK HERE!!!
Old 02-13-2009, 12:44 PM   #21
moses
Why do you have to hold the gas pedal down? Would it be lower or higher?
Old 04-20-2009, 10:17 PM   #22
BIGLERK'S 240SEXY
BIGLERK'S 240SEXY's Avatar
BIGLERK'S 240SEXY is an unknown quantity at this point
Question Ka-t troubleshooting
ok here's the deal i was driving my car around last week,it was running perfect than all the sudden i pull in the driveway and it start's running like s***!!! I'm not sure why, i popped the hood and the motor was pretty hot,not sure how hot cuz my temp gauge is broken,im just tryin to see what's up with it,did a compression check and only one piston had a normal reading,oil looks good ,and i didn't see no blue smoke indicating that the oil rings are bad,i took the head gasket off and it doesn't look bad,shoot me ur opinion or just pm me thanks
BIGLERK'S 240SEXY is offline   Reply With Quote
