Old 03-03-2003, 12:49 PM   #1
Tubed4evr
Tubed4evr is an unknown quantity at this point
Installing BV TC Rods
Hey guys I am about to put the battle version tension rods on my S13 and just wanted to know how other people adjusted them. It says on the website to start with the ends bottomed out and then adjut to length. Did you just eyeball to make it as close to the same length as stock rod? Did you just adjust it while it was on the car to make holes line up? I'm just about to put the car up so any help is appreciated.
Also for the people who have already intsalled these, was an alignment necessary?
Ryan
Tubed4evr is offline   Reply With Quote
Old 03-03-2003, 12:51 PM   #2
Dousan_PG
Dousan_PG's Avatar
measure it up to match same as your stock ones as close as you can.
get an alignment
you MUST get an alignment unless you know how to do it yourself to factory specs.
wrong caster setting=kill tires.
Aaron
Pink GodziRa
