Old 02-13-2009, 06:30 PM   #1
playastarkz123
playastarkz123's Avatar
playastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura about
Studdering problem.PLEASE HELP!
OK so i have had this problem for along while and im just sick and tired of it. I have an s13 sr20det, the problem is that when start the car its idles fine at about 1k but it sounds like its a wrx (studdering) it sounds like this when i drive too, all the time.
I did a test to see if it was my injectors one by one and taking notice of any changes in idle. Cylinder one had no change. so i replaced it ...same problem.
i have also changed the plugs, fuel filter (z32), checked grounds, vac, and boost leaks.
I dont loose boost but or idle low, jus this stupid studdering sound. Some times i get a more lean than normal afr reading from wideband also.
any ideas?
playastarkz123 is offline   Reply With Quote
Old 02-13-2009, 06:47 PM   #2
wrxn240
wrxn240 is on the path to ruinwrxn240 is on the path to ruin
coil? this happened to my friends 240 and the problem was fixed when he replaced his coil.
wrxn240 is offline   Reply With Quote
Old 02-13-2009, 08:22 PM   #3
esqueue
esqueue is an unknown quantity at this point
Try swapping the coil of the one that made no difference to another and then unplug the injectors to see if there is a change. A change is a good thing as you will know it is a bad coil.
esqueue is offline   Reply With Quote
Old 02-13-2009, 09:12 PM   #4
playastarkz123
i got this same suggestion from my brother..ill try it the morning
