Old 02-16-2009, 09:42 PM   #1
toointoxicated62
toointoxicated62 is an unknown quantity at this point
oem and after market oil pressure sensor
I need a T so i can run the oem and an after market oil pressure switch. Can anyone point me in the right direction? I tested to see what the oem switch is and its a 1/8 pipe thread. Havent had a chance to see what the after market one is but can someone give me a link to a T fitting with one male and two female 1/8 pipe thread fittings?
Thanks for your time
toointoxicated62 is offline   Reply With Quote
Old 02-17-2009, 07:12 AM   #2
projectRDM
projectRDM's Avatar
Horrible idea. Really. Throw the OE sender away, thread your new one right into it's place. You'll realize your idea was bad when you change the sender out yearly due to severe oil leaks.
FORMERLY R240NA
Old 02-17-2009, 07:22 AM   #3
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
that or in my case when the T breaks... the way i did it was i got the autometer adapter for the sending unit to the block, which happens to be the same thread pitch as a grease gun line, 1/8 npt, ran that to the shock tower and run the sensor there. the reason you dont need the stock sender is because all it does is trigger the dummy light. if the sensor isnt there the light will never come on. Done and Done
Slip Gypsies Blog
not sure if you realize this
Old 02-17-2009, 08:13 AM   #4
toointoxicated62
Iwas just assuming i needed the oem sending unit. Also i seen someone just T it off so i assumed that is what you suppose to do :/
Thank You for the help
Old 02-17-2009, 09:34 AM   #5
slider2828
slider2828's Avatar
NISsport.com - Unique products for racing
Will have the fitting you are talking about. I run one... Awesome product.
Turn and Burn!
Old 02-17-2009, 11:06 AM   #6
projectRDM
projectRDM's Avatar
Why? So you can throw a rod? The OE pressure sender is just a switch, it trips at 8psi. By that time unless the car is idling you've already skinned the metal off every bearing in the bottom end. Remove it. You won't have a light come on if that's your concern.
FORMERLY R240NA
Old 02-17-2009, 12:00 PM   #7
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
the dummy light is good for when youve just dropped in a built motor and before you fire it up you want to make sure you build oil pressure, but beyond that its useless. my motor blew before the oil light even came on.
invest in a good aftermarket guage (full sweep electrical is nice) and ditch the oem piece
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 03-25-2009, 09:43 AM   #8
toointoxicated62
i have an aftermarket guage and i went to home depot to try and find an adapter lol the sensor is 1/4 compression thread where can i get an adapter :/
