Old 02-18-2009, 08:04 PM   #1
unfuxwitable
unfuxwitable's Avatar
unfuxwitable is an unknown quantity at this point
Non 240 question - 4g63 removal
i am parting out my 95 eclipse gst. the money i get from this is going to my s13 coupe. i dont have an engine hoist and i would like to not have to rent one. is it possible to remove a FWD motor without a hoist. the whole car is in jackstands right now. can i take off the radiator core support and wheel out the motor? if i did that could i still tow it out without welding shit? im stumped and i NEED to get this motor out!
unfuxwitable is offline   Reply With Quote
Old 02-18-2009, 08:29 PM   #2
HyperTek
u need a hoist.. or if you have a group of friends.. a chain, and maybe a barbell .. lol.. my friends put a engine in like that lol
do it right so you dont injure yourself.
If you can lift the front up, you could remove the cross member and drop the engine underneath, but you wont be able to tow the car without the wheels
Keep it Classy
Old 02-19-2009, 12:43 AM   #3
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Drop the motor and trans out from the bottom, and lift the car up around it. It is easy.
-Kyle
Old 02-19-2009, 10:21 AM   #4
Daniel.
Daniel. is close to perfectionDaniel. is close to perfectionDaniel. is close to perfectionDaniel. is close to perfectionDaniel. is close to perfectionDaniel. is close to perfectionDaniel. is close to perfectionDaniel. is close to perfectionDaniel. is close to perfectionDaniel. is close to perfectionDaniel. is close to perfection
Send a message via AIM to Daniel.
qft.
easiest way to remove a 4g63.
Daniel. is offline   Reply With Quote
Old 02-19-2009, 12:54 AM   #5
Charlie
Charlie is on the path to ruinCharlie is on the path to ruin
Seriously
Charlie is offline   Reply With Quote
Old 02-19-2009, 01:13 AM   #6
unfuxwitable
hahahahah maybe. i might just cut the top bar off the radiator support. i put a bottle jack between two beams and cranked it up to break the welds. the lower beam is realllyy thick and welded on good so i might jack the motor on top of it and lift it over the beam. aghh. if a car is on 4 jackstands is it bad to lift up one end alot higher than the other side? it wont slide off the stands?
Old 02-19-2009, 02:33 AM   #7
soreballz
soreballz's Avatar
Trader Rating: (22)
Put the rear wheels on the ground during this process. If the car is floating, you're gonna have to lift it waaaayy too high, and yes, you run the risk of having the car slip off of the stands.
-Kyle
