Old 02-19-2009, 01:02 PM   #1
jspeedm
jspeedm's Avatar
Trader Rating: (26)
jspeedm is on the path to ruinjspeedm is on the path to ruin
Feedback Score: 26 reviews
s14 S14 airbag delete
Does anybody know what the resistance in the airbag is so that I can add a resistor to turn off the airbag light
http://i404.photobucket.com/albums/pp128/jspeedm/Picture097.jpg
jspeedm is offline   Reply With Quote
Old 02-19-2009, 01:38 PM   #2
vaughn4
vaughn4's Avatar
vaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to behold
since your bag is out, the srs system wont work... why not just remove the lamp from the cluster?
vaughn4 is offline   Reply With Quote
Old 02-19-2009, 02:00 PM   #3
jspeedm
jspeedm's Avatar
Trader Rating: (26)
that is why i want to find the resistance so i can put a resistor in. that will trick the module into thinking that there is an airbag there, that way the passenger airbag will still work and there will be no light.
Old 02-19-2009, 02:23 PM   #4
vaughn4
vaughn4's Avatar
gotcha.. test the resistance of the bag you removed.
Old 02-19-2009, 02:30 PM   #5
Chad4061
Chad4061's Avatar
Chad4061 is an unknown quantity at this point
if you find out the resistance let me know cause i need to put a resistor in mine as well
Chad4061 is offline   Reply With Quote
Old 02-19-2009, 02:40 PM   #6
vaughn4
vaughn4's Avatar
I have one laying around in my garage. i will test it out and let you know.
Old 02-19-2009, 02:43 PM   #7
jspeedm
jspeedm's Avatar
Trader Rating: (26)
i would have done that, but there is a high possability that the airbag will deploy when you send current through it to test for resistance.
Old 02-19-2009, 03:29 PM   #8
vaughn4
vaughn4's Avatar
Why would you send current through it to test resistance?
Old 02-19-2009, 04:09 PM   #9
devnull
devnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymore
That's how multimeters work when checking resistance...applies a small voltage and measures how much comes back.
devnull is offline   Reply With Quote
Old 02-20-2009, 12:21 PM   #10
vaughn4
vaughn4's Avatar
so it's obviously less they 9 volts right? you think that would set off a bag?
Old 02-23-2009, 02:55 PM   #11
jspeedm
jspeedm's Avatar
Trader Rating: (26)
ok, so i just went down to ASPEC and bought the airbag delete harness for $20.
easy and done.
Old 02-23-2009, 04:13 PM   #12
maxlineGTR
maxlineGTR is an unknown quantity at this point
where is the ASPEC at?..I wanna do the same
maxlineGTR is offline   Reply With Quote
Old 02-23-2009, 05:26 PM   #13
jspeedm
jspeedm's Avatar
Trader Rating: (26)
they're in south el monte A Spec Products just call them.
Old 02-24-2009, 11:19 AM   #14
Jus Skott
Jus Skott's Avatar
Jus Skott can only hope to improveJus Skott can only hope to improve
Send a message via AIM to Jus Skott
fyi you can and i have set air bags of w/ a 9volt battery.
Looking for yard parts, PM me.
Jus Skott is offline   Reply With Quote
Old 02-26-2009, 09:17 PM   #15
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
considering the auto system runs on 12V, I am surprised people doubted that.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 02-27-2009, 10:17 AM   #16
Ali 556
Ali 556 is a well-known jackass
dunno,
IIRC when S14 pass Side air bag deploys it will destroy your dash....if you need new ones i've just disconnected my driver And pass siad air bags....
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 05-19-2009, 09:49 PM   #17
chato de shamrock
chato de shamrock's Avatar
chato de shamrock is an unknown quantity at this point
easy and done.
That air bag delete harness is made by Works Bell right?
I bought their short hub w/SRS but the connection on the resistor wire didnt fit the type of connections my S14 has (white connection shown in 1:55 and yellow connection shown in 2:20 of this video).
YouTube - NRG Steering wheel quick release how to install 101 tech
I carefully broke off the plastic connection on the WB resistor and pulled the resistor off, plugged it on the SRS hub and nothing. The SRS light still blinked. I then tried plugging it on the yellow connection and still nothing.
chato de shamrock is offline   Reply With Quote
Old 05-20-2009, 05:57 PM   #18
jspeedm
jspeedm's Avatar
Trader Rating: (26)
did you reset the light?
Old 05-20-2009, 08:35 PM   #19
chato de shamrock
Messing with the ECU to reset the light? I know where the ECU is and how to pull the plastic covering the ECU, but dont know how to pull the ECU out much less reset it.
Old 05-20-2009, 09:13 PM   #20
projectRDM
projectRDM's Avatar
No. The ECU has nothing to do with the SRS system. Do a search please, we've covered this a million times, same procedure for diagnostics of the SRS system, key on, depress switch 7 times in 5 seconds, etc.
FORMERLY R240NA
Old 05-25-2009, 11:22 PM   #21
chato de shamrock
Ok. I did research and got tons of info. I tried the "push 5 times in 7 seconds" just like the manual says but it didn't seem to work. I also tried the "7 times in 5 seconds" and oddly that did work. The code I got was the light turned on for 3 seconds then off for 2,3 seconds and then flashed 2 times. Then it went off and restarted sending the code. I turned the key back to the off position and then pushed it back to the on position, then did the 7 times in 5 seconds. I counted 1-1000, 2-1000 and so on until I did 7 seconds and pressed the door switch one more time. What happened next was the air bag light went back to flashing on and off like in the first place. I tried it over and over on saturday and again today, monday, and it did the same thing. I managed to get it on diagnosis mode time and time again (it gave me the code) then when i tried reseting it would get off diagnosis mode and went back to flashing off and on. By the way, the resistor is plugged on all the way. I also tried disconnecting the car battery but so far no success. I'm driving it around in diagnosis mode right now.
