Old 03-05-2003, 10:41 PM   #1
SixthSpeedRacer
SixthSpeedRacer is an unknown quantity at this point
Stock Motor vs SR20??? I'm Confused...
I am still Learning.....
I am very new to Nissans! So...........
If the stock motor in a 240SX is 2.4 Liters then whats so great about the SR20 if its only 2.0 Liters..............??????????
I'm so confused!
Please clear this up for me............Thanks so much!
SixthSpeedRacer is offline
Old 03-05-2003, 10:46 PM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
the SR comes turbocharged.
AceInHole is offline
Old 03-05-2003, 11:06 PM   #3
orange-grey
orange-grey is an unknown quantity at this point
The KA24 is a warmed-over pickup truck motor. Long stroke, weak rods, small cams, breathes like an asthmatic gopher. Good for trying to blow up, or like me, get you to work.
The SR20 was forged by the hands of Mr. K on the top of Mt. Fuji as the worlds greatest race motor and pinnicle of JDM ricer fappiude. They have been known to survive nuclear blasts on occasion and put out 800 hp with just an aquarium valve. Great for putting in S2000's with nawz and absoulutely critical for being mad tyte JDM dorifto master number one.
orange-grey is offline
Old 03-06-2003, 12:04 AM   #4
some guy
some guy is an unknown quantity at this point
Send a message via AIM to some guy Send a message via Yahoo to some guy
This part is mostly true, but I thought the KA has forged rods from the factory? How much HP can a KA24DE handle without rebuilt?
How HK gansters talk:
°àñRÅüÓÑ = Zebra chops people
Äã‰ò½ª¾Í·ÅñRß^í = If you got enough ginger,let your horse come over here
ÄãÖvØ¿¹í£¿ = What the ghost are you talk?
some guy is offline
Old 03-06-2003, 12:07 AM   #5
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
18psi, and 360some rear wheel horsepower.
-Jeff
Whatup?
Jeff240sx is offline
Old 03-06-2003, 07:42 AM   #6
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
sr20det comes overbuilt and turbocharged. The max safe boost you can run on the ka24de is 7 psi. The engine makes lots of torque down low but itsn' t as much fun to drive as some of the other high revving imports.
the sr20det can produce 200 rwhp on the stock engine and turbo with a boost controller, intercooler, intake, and exhaust. With a larger turbo on the stock engine, it can produce impressive power. Bored out to 2.2 liters with a T05 conversion, one guy makes 600 HP on his.
andrave is offline
Old 03-06-2003, 09:37 AM   #7
Phlip
Yes, I look like that
Phlip's Avatar
*jerk off hand motion*
-Jeff
and from what I understand, you AIN'T going too much further than that without opening your SR, and will still have less torque than your "warmed over truck motor with asthmatic gopher," long stroke is good for something.
P.S. WHAT THE FUCK is an aquarium valve?
Weirdo
And I write too!
Phlip is offline
Old 03-06-2003, 09:54 AM   #8
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
P.S. WHAT THE **** is an aquarium valve
DSM trick, where you use one to make a manual boost controller works pretty well. It was even featured in stupid street or something like that.
SR vs. KA whoo!! yay! yippe!
My view and the bottom line cause I'm the fookin hizzy.
non built ka's blow. Built KA's are fookin monsters. I've riden in stock turbocharged ka's. yay. I've riden in built monster charged ka's YAY!!!!
Driftec
www.midatlantic240sx.com
Foxcolt is offline
Old 03-06-2003, 09:59 AM   #9
Phlip
Phlip's Avatar
Thanks a bunch...
Wasn't it about time for the weekly KA vs. SR?
The final answer that, for some odd reason is always arrived to, now could someone PLEASE lock this damn thread?
Weirdo
And I write too!
Phlip is offline
Old 03-06-2003, 10:00 AM   #10
AKADriver
AKADriver's Avatar
aquarium valve = a plastic ball & spring air valve used in aquarium bubbler systems. In a car you can use one to bleed air off the wastegate actuator line for more boost. Cheap-o manual boost controller.
AKADriver is offline
Old 03-06-2003, 10:05 AM   #11
Phlip
Phlip's Avatar
Cool, I knew what it was, but for some odd reason never thought that someone would trust an engine to something so cheap, nor would I have ever thought of that personally... I'll spring for a real boost controller whne I get to that part of my buildup.
Weirdo
And I write too!
Phlip is offline
Old 03-06-2003, 10:06 AM   #12
Foxcolt
Foxcolt's Avatar
What do you mean "bleed air of the wastegate actuator line" .
if you mean redirect air then you'd in essence be causing a vaccum leak. Or something of the sort.
All boost controllers manual or electronic "block" air from the wastegate actuator until a specific pressure has been achieved. Then they let the air into the actuator or actuator line "depending on setup" to actually open the wastegate.
I'm sure you knew this I think your post was a tad bit misleading though.
Driftec
Foxcolt is offline
Old 03-06-2003, 10:12 AM   #13
Jeff240sx
I hate you too...
Jeff240sx's Avatar
This whole damn post is wrong!
First, 7psi is the max safe boost you should run on the STOCK FUEL SYSTEM! I am pretty sure that I've said the stock KA can go to 18psi! TY did it, and Dennis runs 15psi daily, at 350rwhp.
Woot! Turbo - $2k, JUN stroker kit - $3k, ect.
Duy built a KA to 500rwhp with a t70, THEN added a 150shot of nitrous on top of that!
Can we stop debating the merits of KA vs. SR now? It seems to be a preference thing.
-Jeff
Whatup?
Old 03-06-2003, 10:16 AM   #14
Jeff240sx
I hate you too...
Jeff240sx's Avatar
I don't know. My friend's HKS manual boost controller in his Z31 was a bleeder valve. So are aquarium valves. His kit came with 1 T-fitting to splice into the actuator line, and then the 3rd line went to the MBC. From the MBC, the instructions said to route the "dump line" from the MBC into the engine bay.
I was always under the assumption that if you could control the ammount of air that is bieng released, the turbo would have to spool that much more to overcome the air loss, and still actuate the wastegate. If the car runs 7psi stock, then you lose 2 psi through the vaccuum leak, means the actuator would "see" 5psi, but be making 7. So, it would make 2 more psi to overcome that loss, putting the output at 9psi, yet the wastegate is only seeing 7.
-Jeff
Whatup?
Old 03-06-2003, 10:18 AM   #15
AKADriver
AKADriver's Avatar
'tis exactly what I'm talking about:
The DSM guys might do it differently, this is the classic turbo dodge wastegate bleed.
Old 03-06-2003, 10:22 AM   #16
Foxcolt
Foxcolt's Avatar
-Jeff
interesting... from what you say it seems as though some of the older boost controllers were like that. Don't see the point though. Seems like a pretty inefecient design. I'm sure that would cause problems in high boost situations. ie running rich etc..
Akadriver: Pictures make everything better! I understand what you were saying but like I just stated it seems like a very faulty design. To just let vacuum into the atmosphere? vierd. that would cause you to jerk every time the wastegate would open at full throttle.
Driftec
Foxcolt is offline
Old 03-06-2003, 10:23 AM   #17
Phlip
Phlip's Avatar
-Jeff
Agreed, now I will give you a dollar if you lock this thread.
Weirdo
And I write too!
Phlip is offline
Old 03-06-2003, 10:29 AM   #18
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Paypal @ [email protected]. Pay up!
-Jeff
Whatup?
Old 03-06-2003, 10:31 AM   #19
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Oh yea! Start a new topic if you would like to discuss the merits of bleeder valve vs. redirection in MCBs.
-Jeff
Whatup?
