![]() Join Date: Jul 2005
![]() ok my cluster wont light up. each time i turn the head lights on the cluster wont light up. i checked the fuses on the kick panel and everything seems ok. my radio and dome light works. just not the cluster light. any ideas ?
#6 |
![]() Join Date: Jun 2008
![]() Feedback Score: 6 reviews
TCU it is. mine did the same thing. open up the kick panel. unscrew and unplug the little white box.
use a knife or screw driver to upen up the top and pull out the circuit board. you'll most likely see a burned out circuit. all i did was solder a wire in place of the burned out circuit haha works great nowww |
#8 | |
#12 |
![]() Join Date: Nov 2008
same shit different car...mines doing the same thing, i guess ill try to yank a tcu out of a junk yard car and see if that works. i checked for power. power is all there. ground is good.....wtf?
#16 | |
![]() Join Date: Feb 2008
[quote]I have seen people fix the problem by grounding the red wire with yellow stripe. This will fix the problem, however the dimmer switch will not work after you have done that.[/quote]
Copied from i don't remember where. Ground that wire out, should be in the cluster with the radio harness. Fixed it for me. And next time search.
Check out the coolest new thing: toddrickkkkk.blogspot.com |
#17 |
if all else fails pull out the cluster and check the illumination wire on the subharness i believe it is a blue wire with red stripe... check for power with the lights on and that will narrow things down for you
