Old 03-07-2009, 11:41 PM   #1
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Kouki Tail Light issue with inner circle lights
Well my kouki tail lights where working properly before with no issues. Then one day one of the inner lights went out on the RH side. So I bought new bulbs and for some reason the the 2 inner(closet to reverse lights) circles don't light up with the lights on or when I brake.
I checked the fuses and their fine, not blown.
Checked the FSM and it says that those bulbs should have a Green/Yellow wire going to them so I checked for voltage and I'm not getting any on those.
Checked for continuity and they're all connected.
Why would it just suddenly not work anymore?
I'm not too good with electrical so I figured I'd ask. Searched but didn't find much help.
duffman1278 is offline   Reply With Quote
Old 03-08-2009, 12:11 AM   #2
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Sorry about not being of any use, I just wanted to remark on the irony of your avatar.
Hope you get help, good luck!
Old 03-08-2009, 08:40 AM   #3
g6civcx
g6civcx's Avatar
Start over. Too many issues to diagnose at the same time.
Pull out the FSM and check all the wires. Then look for shorts and shoddy connections.
Come back after you've learned how basic electrical wiring works.
Old 03-08-2009, 01:23 PM   #4
cotbu
cotbu's Avatar
Does the 3rd brake light work? I'd probably try to rule out the tail light connections first then move toward the front. Do the 4ways, blinkers and all work? It's got to be a simple solution...
All in all best advice is right here:
Old 03-08-2009, 01:41 PM   #5
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
check your wires for the 3rd brake light and the rear defroster
its located on the hatch when you open it
take a look at it make sure all the wires are not chewd up or anything
i had this problem my wires where gettin chewd up from everytime i will open and close the hatch just wired them back up and the tail lights worked
airhead is offline   Reply With Quote
