Old 03-09-2009, 01:28 AM   #1
510-SR20DET
510-SR20DET's Avatar
510-SR20DET is an unknown quantity at this point
Unhappy Ball join trick
okay so i tried to install the 5lugs for my 180sx today. i took the bottom ball join out, and now i cant put it back in. The whole ball join keep spinning when i try to tighten down the nut. Do any of you know the trick to this to hold the ball join in place while i tighten down the nut?? i dont want to replace my ball join/nut.
510-SR20DET is offline   Reply With Quote
Old 03-09-2009, 05:24 AM   #2
Sileighty_85
Sileighty_85's Avatar
why did you take it out? are you using S14 hub assembly? if so you need to use an S14 balljoint.
here what i did to install mine
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-09-2009, 09:28 AM   #3
projectRDM
projectRDM's Avatar
Threads are damaged. Take it off the spindle and chase the threads while holding the joint itself with a pair of pilers down below the threaded portion. Did you hit the joint itself to remove it? You may have even crowned it enough to be unusable.
FORMERLY R240NA
Old 03-09-2009, 09:48 AM   #4
druthafoo
druthafoo's Avatar
druthafoo is an unknown quantity at this point
I know you dont want to replace em... but theyre probably pudding by now anyways right? So it might be a good idea to replace em while you can, unless you dont have money :/.
***PM for Stereo Help***
Eclipse55090CrystalSSCS6SIMAG
druthafoo is offline   Reply With Quote
Old 03-09-2009, 09:54 AM   #5
Touge180sx
Touge180sx's Avatar
Touge180sx is an unknown quantity at this point
Not always the case, Sometimes they just wont fully tighten. If you can use air impact wrench or whatever, Dont over tighten it though. You can also use a prybar and apply pressure to the knuckle/spindle and this usually works also, But if the threads are damaged then you should just replace the ball joint.
Touge180sx is offline   Reply With Quote
Old 03-09-2009, 10:22 AM   #6
initial_drifter
initial_drifter's Avatar
initial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of light
I forget if 240's had the allen hole on top of the bolt
The ball joint when pushed up will usually be enough clamping force to tighten it down.
If it still spins, it's more than likely that the joint itself is done
ps. why use something that'll need replacing again in the near future?
initial_drifter is offline   Reply With Quote
Old 03-09-2009, 10:26 AM   #7
Marc240
Marc240's Avatar
Marc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-known
Why did you take the ball joint out? If your just swaping hubs all you needed to do was rotate the axle back and forth so you can fit the 17mm socket to loosen the 4 back bolts.
Marc240 is offline   Reply With Quote
Old 03-09-2009, 10:30 AM   #8
aznpoopy
aznpoopy's Avatar
the joint is done and needs to be replaced.
i had to rock a bad balljoint for a week so i went through this before. if you really want to get it on, force down the boot and get some vice grips on it under the nut while you tighten the top down with a ratchet. when you thread it down low enough move the vice grip to top side and finish tightening it with a wrench
but yeah, really you should just replace the balljoint.
aznpoopy is offline   Reply With Quote
Old 03-09-2009, 12:39 PM   #9
ixfxi
Guest
Posts: n/a
Originally Posted by Sileighty_85 View Post
too hard to use a press, eh?
jeez.
Old 03-09-2009, 12:54 PM   #10
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
The ball joint is good, you just need to place a jack underneath the ball joint and tighten. This happens every time to me.
Bigsyke is offline   Reply With Quote
Old 03-09-2009, 01:46 PM   #11
510-SR20DET
i had to cause i was installing the z32 e-brake also and i need to bang the 27mm bolt in place.
the ball join is good, not broken seal/boot, the thread is good also. just that this thing is 20years old and its hella sticky. you know how it is w/ old ass nut and bolt.
Old 03-09-2009, 02:31 PM   #12
loveskylines
loveskylines's Avatar
loveskylines has a spectacular aura aboutloveskylines has a spectacular aura aboutloveskylines has a spectacular aura aboutloveskylines has a spectacular aura aboutloveskylines has a spectacular aura aboutloveskylines has a spectacular aura about
ball joints are overrated....u dont need them... just take it off and use it for a shift knob
No MORE S13!!
SC300!!!
loveskylines is offline   Reply With Quote
Old 03-09-2009, 05:12 PM   #13
510-SR20DET
Go do something useful in your life!
Anyway, i did it guys. What i did was i use the combo of jack and strut. I use the strut to compress it down while the jack compress it up. 2500 lbs of compression makes the ball join stay in place while i tighten the nut down.
Old 03-09-2009, 05:53 PM   #14
Sileighty_85
jeez.
Haha I wish, didnt know where to find one at the time I had just moved to that town.
It was rainy and had no transportation , and just scrounged around the garage until i came up with this concoction, definatly ghetto but worked like a charm though hahaha
後輪駆動車1番
1986 SR86 - 200ish
