Old 10-30-2001, 08:42 PM   #1
gh6o6
gh6o6 is an unknown quantity at this point
Im very confused on the CAE and ram intake for a 96 se.  Can anyone tell me how this works? and is it effective? what kind of hp increase can i expect?
gh6o6 is offline   Reply With Quote
Old 10-30-2001, 08:51 PM   #2
BlankFlip
BlankFlip's Avatar
BlankFlip is an unknown quantity at this point
cae, cold air extension. it extends ur filter away from heat, more air flow, don't know about hp, shouldn't be 2 much though.
BlankFlip is offline   Reply With Quote
Old 10-30-2001, 08:54 PM   #3
gh6o6
yeah i understand that but i wanted to know where it extends to.  The wheel well? and is it a pipe that goes over the cone filter?
Old 10-30-2001, 09:28 PM   #4
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
no, it's actually an extention to the original pipe, but yes, it does go down into the wheel well. You'll have to turn the wheels all the way to the left to be able to get at it from below and pull it down in.
transient is offline   Reply With Quote
Old 10-30-2001, 11:45 PM   #5
Guest
Posts: n/a
I turned my wheels all the way to the right when I put mine on.
The CAE goes through the hole that leads to the resonator box below the stock airbox. If you've already removed your stock airbox, you should be able to see the hole. Can't miss it. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> Remove the plastic inner wheel well fender when you're taking off the resonator box or putting on the CAE.
http://danio.nismo.org/cae.html - Take a look at the pictures to see what I'm talking about.
(Edited by danio at 10:47 pm on Oct. 30, 2001)
Old 10-31-2001, 06:16 AM   #6
gh6o6
that helps alot thanks - i understand now. &nbsp;
but if you ever drove through a deep puddle your screwed because it will suck water
Old 10-31-2001, 09:48 AM   #7
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
Will the intake fit both s13 and s14. &nbsp;Iheard somewhere that they should. &nbsp;Is this true?
burgy240 is offline   Reply With Quote
Old 10-31-2001, 09:59 AM   #8
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from burgy240 on 9:48 am on Oct. 31, 2001
Will the intake fit both s13 and s14. Iheard somewhere that they should. Is this true?</td></tr></table><span id='postcolor'>
Not the intake, but the cold air extension...let me clear it up:
91-94 has an intake
95-96 has an intake
97-98 has an intake
but they all (91-98) use the same cold air extension pipe
Kid Zelda is offline   Reply With Quote
Old 10-31-2001, 10:07 AM   #9
burgy240
burgy240's Avatar
thank you
Old 10-31-2001, 11:19 AM   #10
vancouvers14
vancouvers14 is an unknown quantity at this point
Send a message via ICQ to vancouvers14
I live in the rainiest city in North America. &nbsp;We've had 100 days of rain in the past 4 months, and the only time water got on my filter was when I accidentally sprayed it with the hose when i was washing the car.
vancouvers14 is offline   Reply With Quote
Old 10-31-2001, 01:52 PM   #11
konkman
konkman is an unknown quantity at this point
Unless you're planning on running you car throuhg creek beds, you should be fine. &nbsp;If your still worried, AEM makes a CAI bypass filter for your intake tube. &nbsp;If you submerge your filter with water it will grab air from the bypass filter.
konkman is offline   Reply With Quote
Old 10-31-2001, 02:16 PM   #12
BlankFlip
BlankFlip's Avatar
danio, nice instructions. i also like the &quot;nice car&quot; captions on the first n last photos, n how u pointed out the laundry basket being a part of the installation process <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 10-31-2001, 02:42 PM   #13
vancouvers14
you don't even have to completely remove the cover. &nbsp;you can just move it out of the way
Old 10-31-2001, 02:55 PM   #14
transient
transient's Avatar
my bad on turning the wheels. Actually though there's also an intake for 89-90, just no extension, and it won't suck water up unless it's submerged for a while. It's been tested
Old 10-31-2001, 04:09 PM   #15
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from BlankFlip on 1:16 pm on Oct. 31, 2001
Thanks. &nbsp;^_^
Old 11-01-2001, 06:21 AM   #16
gh6o6
thank you i think the intake, bypass and cae will be and upgrade on my list.
how much should these things cost?
Old 11-01-2001, 01:50 PM   #17
BlankFlip
BlankFlip's Avatar
around $300 or so?
Old 11-01-2001, 07:16 PM   #18
chickenmanq
chickenmanq is an unknown quantity at this point
Does anyone know of a Supercharger for the ka24e engine? &nbsp;I'm running a 96 pickup, which gives me ample room. &nbsp;I'm curious if the ECU will screw up after I add a supercharger.
chickenmanq is offline   Reply With Quote
Old 11-01-2001, 07:19 PM   #19
chickenmanq
by the way, if you want to do a cold air intake, make one yourself. &nbsp;PVC and 10 bucks of appropriate fittings works just fine.
Old 11-01-2001, 09:53 PM   #20
Archangel
Archangel's Avatar
Archangel is an unknown quantity at this point
Send a message via AIM to Archangel
Those instructions are really helpful danio.
(the whole picture is worth a thousand words thing...)
BTW what did you have problems with when you tried to install the stereo? &nbsp;I just did mine and it took me a long time to get that factory cd player outta there. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=':('>
Archangel is offline   Reply With Quote
Old 11-01-2001, 11:35 PM   #21
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Archangel on 8:53 pm on Nov. 1, 2001
BTW what did you have problems with when you tried to install the stereo? &nbsp;I just did mine and it took me a long time to get that factory cd player outta there. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=':('></td></tr></table><span id='postcolor'>
Hehheh... We couldn't unplug those white plastic things in the back. Even if we did manage to unplug them, we wouldn't know which wires connected to which anyway. Just wanted to see how it looked. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'> I got it installed professionally for free (plus hidden fees -_-).
