Old 03-11-2009, 12:41 AM   #1
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
Sr20det Low vacuum at idle..pondering
ok guys so I had my engine rebuilt a few months back due to 2 spun rod bearings during tuning. Anyways long story short, My engine was rebuilt where it was tuned and I recently did a vacuum test and the reading was 12inHg. I know that normal reading range between 17-21inHg. So, My question is..What do I do or go about this problem? A reading that LOW would indicate either an intake manifold leak or late valve timing. So again..How would I go about the process or figuring out how to resolve this situation? Keep in mind that I haven't modified anything since the rebuild. Stock rebuild with hks step 1 256 cams...very mild and shouldn't cause low vacuum. There isn't enough valve overlap at idle. Any Ideas? Should I take off the valve cover and see if the timing marks line up???
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
