Old 03-11-2009, 11:30 AM   #1
Brian W.
Brian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfection
Send a message via AIM to Brian W.
SERIOUS SR20DET STROKER MOTOR for sale...
Ok, We are selling this Motor.. It will be practically brand new. Its an s13 SR20DET and it will be sold as a complete long block from valve cover to oil pan.
This is the motor out of JR's S14 that did not last very long(story here: DRIVERS>>VAUGHN GITTIN JR BLOG ENTRY#3 - Speedhunters)
Specs are as follows:
MA-Motorsports built 2.2 Liter S13 SR20DET long block:
-JE 9:1 Custom stroker pistons
-Bored 20 over
-Brian Crower Billet Stroker Crank
-Brian Crower 625+ Stroker Con rods
-chamfered oil passages in block
-ACL Race Rod Bearings
-ACL Race Main bearings
-ARP GTIR Oversized head studs
-Drilled head and block for oversized head studs
-Apexi Head Gasket (cut for oversized studs)
-Open combustion chambers, polished
-Radius valve job
-Solid Lash Adjusters (with initial setup)(or hydro LAs)
-Brian Crower stainless Valves
-Brian Crower Ti retainers and valve springs
-Brian Crower Stage 2 camshafts
-JUN Cam gears
-Custom Blue paint valve cover with DA/ American flag logo vinyl
-Greddy Oil Pan
-S14 SR Water Pump
-Signal Carbon coilpack cover with the vinyl over it.
-A couple accessories will also be included: alt. w/ powdercoated brackets, PS pump w/ powdercoated brackets
This engine is at the machine shop right now getting fresh bearings put in and all tolerances checked, straightened, etc. and everything will be cleaned and like new. When i get it back from them i will personally assemble it as a complete long block and can ship right away.
This is pretty much the same motor i run in my car.... It RIPS! I can advise on various turbo setups to run with this engine to meet your power goals.
Serious inquires please email me.
$6000.00 OBO If you are serious, and want a real deal motor and have some money... shoot an offer.
www.ma-motorsports.com
-Fab work, builds, swaps, dyno tuning
Brian W. is offline   Reply With Quote
