Old 03-10-2003, 11:04 PM   #1
Tictakman
Tictakman is an unknown quantity at this point
What faults to look for in a used 240...
topic says it all. im going to be buying a 240sx very soon and wanted to know where the problem areas were on the 240s. ive heard stuff about the muffler guard rattling and the timing chain. anything else i should know about or look for.
the car im looking at is in Tenn, it has 130,000 miles on the chassis and 70,000 on the newer engine.
what do u guys suggest looking for or asking about?
thanks a lot
Zak
Tictakman is offline   Reply With Quote
Old 03-11-2003, 01:09 AM   #2
kapower
kapower is an unknown quantity at this point
you should look for major body damage that has been covered up; like overspray on windows & in the wheel wells and taping on the body will reveal any bondo by the sound . a carfacts history report would not be a bad idea. most s13's have a rust problem on the hatch beacuase of a spoiler issue. check underneath the spare tire for water. also look for smoke coming from the shifter boot that is a common problem with 240's; most of the time it is just a $10.00 part cuasing the problem (the inner shift boot is usually torn letting some of the burnoff from the transmission seep in to the cabin) or it could be a more serious problem ( transmission seals could be leaking and driping on your exhaust on top of having a torn inner shft boot )99% of the time it is just the inner shift boot. that is all i can think of right now but good luck on finding a new ride
kapower is offline   Reply With Quote
Old 03-11-2003, 06:08 AM   #3
Fireball240SX
Fireball240SX is an unknown quantity at this point
Send a message via AIM to Fireball240SX
I have a bondo front end and rear quarter panel...but a Silvia front end will take care of that and the rear if its not that much bondo i might leave it for fun?
2 Liter is my Weapon of Choice
Fireball240SX is offline   Reply With Quote
Old 03-11-2003, 06:29 AM   #4
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
check for holes in the floor underneath the downpipe before the catalyser...
also check for rust around the shocks towers, under the spoiler, under the 3rd brake light, etc.
-> HaLo
Race Car: '98 E36 BMW M3
Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
Old 03-11-2003, 08:09 AM   #5
Tictakman
arlight that sounds good guys. ill be lookig for that and im gonna look to see if the joints are wok out on the steering components etc. Are the steering racks and pumps good on the 240s? On my od car i know there was a bad history about the rack and pinion going out. Also, is there anything for the engine i should be looking for besides oil and antifreeze leaks?
Zak
Old 03-11-2003, 09:58 AM   #6
n/arotary
n/arotary is an unknown quantity at this point
I would look and see how bad of a timing chain rattle it has, if it has it at all. You can definetly hear it once you lift up the hood. You can do a search for "Timing Chain Rattle" on this board, and find out more information than you ever wanted to know.
n/arotary is offline   Reply With Quote
Old 03-11-2003, 12:30 PM   #7
Red
Red's Avatar
Red is an unknown quantity at this point
One thing I found on my 95 is that the muffler is rusting.... The shocks were GONE! not missing.. they just did nothing at all... Skueeky clutch peddle.. (Easy fix tho..) and umm Leaky Moonroof... (I hate that....) Trunk latch rattles.. (I hear thats easy to fix.) and all my O2 things went out right after I got it.... (I wish I had found this form sooner it would not have cost me 1500$$)
It is my 1st car tho... So I have a excuse
Just some things to look at...
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
http://www.zilvia.net/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 03-12-2003, 02:26 AM   #8
91CRXsiR
91CRXsiR's Avatar
91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self
Send a message via AIM to 91CRXsiR Send a message via MSN to 91CRXsiR
well in the 1.5 years ive had my car
i have
replaced
-starter
-clutch master/slave cylinder
-2 fuel injectors
-front/rear brake pads [ twice ]
-rotors resurfaced
-muffler [ nothing wrong w/ it ]
-tires [ balding when i bought it ]
now things i still need to fix
-timing chain is starting to rattle
-alignment is off
-steering rack is leaking
-engine could use a flush
91CRXsiR is offline   Reply With Quote
