Old 03-12-2003, 06:29 PM   #1
mrmurphz
mrmurphz is an unknown quantity at this point
Send a message via AIM to mrmurphz
camber bolt questions
Can someone explain exactly how the camber bolts work for an s13? I have the ingalls camber kit part 3541 and I'm a little confused as to how they go onto the strut. The instructions aren't helping me very much. Illustrations would help a lot. Thanks guys!
mrmurphz is offline   Reply With Quote
Old 03-12-2003, 07:42 PM   #2
turbo240sx
turbo240sx is an unknown quantity at this point
its just a bolt that replaces the top bolt on the strut, take off the top bolt on the strut housing, put this on ein loosen up the bottom one turn the top one so the lobe on it pushed the camber positve till it is a desired camber, easier to do with the tire off the ground.
240sx s-13 TURBO weekend v-8 killer
90 Talon TSI
WARNING.THIS CAR IS EQUIPPED WITH A TURBOCHARGER. DUE TO POSSIBLE BREATHING PROBLEMS UNDER HEAVY ACCELERATION, ALL FEMALES ARE ADVISED TO REMOVE ANY TIGHT FITTING OR RESTRICTIVE CLOTHING FOR SAFETY.
turbo240sx is offline   Reply With Quote
Old 03-12-2003, 09:04 PM   #3
mrmurphz
I'm still not clear on which bolt the top one is. I know there's two bolts holding in the strut at the bottom and three nuts holding the strut housing in at the top. Sorry about that guys.
Old 03-13-2003, 01:46 PM   #4
turbo240sx
yeah on the bottom where the 2 bolts hold the strut on, you put your camber bolt in the top one of the 2 holes you remove the top bolt totaly. and replace it with the new camber bolt and then turn it to adjust the camber to where you need it to be
90 Talon TSI
Old 03-13-2003, 09:05 PM   #5
mrmurphz
got it...thanks for your help. one more question...does anyone know how to get the piston rod lock bolt off? i can get a deep socket in there, but it turns the piston as i turn the wrench. it's kinda tricky with that deep turning plate at the top.
