Old 03-12-2003, 11:51 PM   #1
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
KA turbo question
ok i have all my parts and ready for the install...
but i had a quick question...
if my manifold and turbo is bolted on.. and all the oil lines are connected.. intercooler and BOV is bolted on...the only thing thats not connected is the wastegate..
correct me if im wrong.. but the turbo wont see boost without the wastegate?.. but will i still be able to run my car???
i know it seems odd... but i want to get everything in... and im still waiting for the wastegate to come in the mail via the UPS fairy...
so if i plug up the wastegate pipe (on the manifold) temporarily, would this be possible doing since the turbo is not reading boost?
my friend said he did it and its ok... but im not really sure....
lets keep the flames to a match size if possible... if not i understand.. LOL..
thanks for any help..
s13silady is offline   Reply With Quote
Old 03-13-2003, 12:58 AM   #2
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
If you plug up the hole on the manifold for the wastegate it'll be boosting as much as the turbo can possibly put out. Wastegate is made to keep the boost from getting past whatever limit you decided to put it at. It does that by letting go all exhaust that would make the turbine push more air into your engine that you desire. As always, I'm not 100% sure but I would play it safe and put on the wastegate first. Otherwise, you will probably end up with a blown motor.
-Juan
240Stilo is offline   Reply With Quote
Old 03-13-2003, 08:49 AM   #3
RacerBoi
RacerBoi is an unknown quantity at this point
Don't run the car with the wastgate hole plugged. As said above the turbo will boost till its past its efficiency and on the way to blowing your engine. Just wait untill you have the wastegate put on and all the hoses hooked up. I hope you have a boost gauge.
RacerBoi is offline   Reply With Quote
Old 03-13-2003, 06:44 PM   #4
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
If you really want to run your car with out the wastegate, just leave the wastegate open, your car will run but there won't be any boost. If you want the most exhilirating drive of your life and a blown motor, plug the wastegate and go drifting, well for about 15 seconds anyways.....
RBS14 is offline   Reply With Quote
Old 03-13-2003, 07:26 PM   #5
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
if you have the ability to plug the wastegate, you can probably just run a dump pipe to wherever you were going to plumb the wastegate to. that would be your best bet.
By that I mean, instead of the wastegate, run a pipe or elbow from the wastegate flange to somewhere you can safely vent exhaust. If you don't plumb it into the downpipe (i hope you were planning on doing so) then your car will be pretty obnoxious as you're running exhaust pretty much straight to the atmosphere(would be more so, but you have a huge sound absorber called a turbine in the way, thankfully).
AceInHole is offline   Reply With Quote
Old 03-13-2003, 11:24 PM   #6
s13silady
s13silady's Avatar
well yah thats what i meant... if i run without the wastegate but the hole is open.. the turbo wont see boost???
im just gonna wait for everything to come in.. but i might as well know about it...
Old 03-14-2003, 01:53 AM   #7
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
yeah, if you have the hole open, it would act as an open wg. Your turbo will still be spooling, but not fast enough to make any boost.
кто болеет за Зенит, у того всегда стоит!
Kreator is offline   Reply With Quote
Old 03-14-2003, 12:56 PM   #8
s13silady
s13silady's Avatar
would this be another way to break in the turbo.. (it is a brand new K's T3) or do i have to break in with it reading boost....
i ask this question because i know i wont break it in when im boosting because ill just romp the gas....
