Old 03-20-2009, 11:05 PM   #1
krislin
krislin is an unknown quantity at this point
Unhappy Pinion bearings needed
Having issues figuring out which pinion bearings I should buy. It seems to be almost impossible to get an actual frickin' part number for the damn things, or a real comparison, but here goes:
I've got a 98 Q45 ring and pinion, 3.69:1, and i want to install it in my non-VLSD pumpkin, with a KAAZ diff. While it's all in pieces, I want to throw in new bearings, just for the fun of it. I can get either bearings for the Q45 or for my 240, but I don't know if they are the same. Does it matter which I use? Are the pinion shafts different sizes? I KNOW they are both R200's, but the Q45's is a R200V. The ones on the side should be for the 240, since the output shafts are standard, but the pinion is from a q45.
I've spent hours on boards searching, and googling, then searching some more. My head hurts. Someone with some knowledge HELP!
Thanks!
91 s13, sr20det
krislin is offline   Reply With Quote
bearings, differential, q45 diff, ring and pinion, why isn't anything simple
