Old 03-23-2009, 09:59 AM   #1
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Stereo + Clock quit working?
So over the past winter, now that im driving my car again, my stereo (Alpine 7876) and my clock dont work. I had to jump my car a few times over the Winter, but I dont think that has anything to do with it.
My radio wont turn on, and the clock wont either. The clock light works, but the clock itself doesnt.
I checked the obvious fuses, but i got nothing. Anyone else have any kind of an idea?
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 03-23-2009, 10:21 AM   #2
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Maybe loose wire. CD player should have a fuse on it. Pull the cd player and check that fuse. I'm not sure if the 2 are related unsure if they run on the same loop.
godsmack is offline   Reply With Quote
Old 03-23-2009, 10:23 AM   #3
lil240sx95
lil240sx95's Avatar
lil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfection
Send a message via AIM to lil240sx95 Send a message via MSN to lil240sx95 Send a message via Yahoo to lil240sx95
check your power wires, then check your fuse. happened to me, and it was the fuse that was burnt.
Greatest band eber.
Originally Posted by DrftKingIII View Post
Shit is hot. I repeat, this shit is hot. Fuckin makes your car look like its from Japan land. Anybody want this thing? Its painted OEM black so it looks satanic.
lil240sx95 is offline   Reply With Quote
Old 03-23-2009, 10:27 AM   #4
peetiewonder
peetiewonder's Avatar
peetiewonder is an unknown quantity at this point
Send a message via AIM to peetiewonder
um... if ur interior lights dont work, and seatbelts dont either with the poweroff its a fuse, i had the same problem. its the 3rd fuse from the top on the right, a red one. otherwise check your TCU box, its the white one under the kick panel on the driver side. its under the fuse box.
My Car is a Hybrid.
It Burns Gas and Rubber.
peetiewonder is offline   Reply With Quote
Old 03-23-2009, 10:59 AM   #5
BlackZenkiS14
Interior lights work fine, only thing not working is the clock and radio head unit.
It wouldnt be a loose wire, it worked fine for 4 years. Something happened over the winter, i guess while jumping it, and now it doesnt work.
My Alpine doesnt have a fuse in the rear
-Kyle
Old 03-23-2009, 12:59 PM   #6
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
If its not a fuse theres an open ckt somewhere....
Start from page EL-118 (118) on http://www.nicoclub.com/FSM/240sx/1995/EL.pdf and print off all the audio schematic wiring diags, use them as your guide.
Get a multimeter and with a continuity tester, test ckt from the fuse outlet on the fusebox to the cd player power and clock power.
I still think its a fuse... make sure when you check your fuses your not just Looking at them. The back of the fuse has two metal surfaces, test for continuity on them to make sure the fuse element doesn't have a feint hairline crack.. Or just swap out other fuses...
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 03-23-2009, 01:20 PM   #7
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
The same fuse that powers the clock powers the radio. Check the radio fuse in your underdash fuse box.
Old 03-23-2009, 02:19 PM   #8
DCP94
DCP94's Avatar
DCP94 is an unknown quantity at this point
check the dome light fuse under the driver side kick panel...it sounds crazy but i was in the same situation..not sure why but check it out
DCP94 is offline   Reply With Quote
Old 03-23-2009, 03:02 PM   #9
projectRDM
projectRDM's Avatar
On S14s the fuse you're looking for is under the hood.
FORMERLY R240NA
Old 03-23-2009, 03:19 PM   #10
BlackZenkiS14
Ok, i'm gonna go through all my fuses again today and see what i find.
Which one under the hood am i looking for?
-Kyle
Old 03-23-2009, 03:23 PM   #11
DCP94
DCP94's Avatar
oh i assumed you have an s13 lol
Old 03-23-2009, 04:22 PM   #12
BlackZenkiS14
Well, all my fuses are good, every single one of them lol. I have no idea what it could be.
-Kyle
Old 03-23-2009, 07:34 PM   #13
opponheimer
Noooooooooooooooooooow do what I said..
Also make sure one of the fuse ports sees 12v with the key "ON"
