Old 03-14-2003, 02:55 PM   #1
zonedout365
zonedout365 is an unknown quantity at this point
Send a message via AIM to zonedout365 Send a message via Yahoo to zonedout365
car wont start, any ideas
Ok this is weird so check it out. My car has been running fine since I got it about 3 months ago, but then suddenly it started to have a hard time starting.
What I mean is that the starter would turn multiple times before starting and sounding like my battery was dying. Well I put in a brand new battery and the other day I was in Target for only about ten minutes and when I came back out and tried to start my car it would do anything.
I mean nothing at all. The starter wouldnt try to turn or anything, not even a jump made it make a noise this time either, any ideas??? Im just thinking my starter died.
Scott Manning
Oceanside, CA
Champagne '95 240SX SE
zonedout365 is offline   Reply With Quote
Old 03-14-2003, 02:58 PM   #2
Dousan_PG
Dousan_PG's Avatar
could be your starter??
im guessing here.
Aaron
Pink GodziRa
Old 03-14-2003, 03:03 PM   #3
s14slide
s14slide's Avatar
s14slide is an unknown quantity at this point
Send a message via AIM to s14slide
also check your cabe connections. I had the same prob at the beginning of winter and come to find out, the negative battery cable was corroded where it attaches to the battery tray giving no ground to it. It got so bad at the end there that the starter solenoid wouldn't even click. Hope that helps.
= My day
s14slide is offline   Reply With Quote
Old 03-14-2003, 04:43 PM   #4
Stee Flo
Endless Knights
Stee Flo's Avatar
Stee Flo is an unknown quantity at this point
does it make any noise when you turn the key? If the car doesnt try to turn over and you hear a click, it probably is your starter. If your lights and radio and everything electronic dont work , could be your alternator. Try taking a wrench or a small hammer and bang on the starter a few times. Then try starting the car. If it starts up fine, its your starter.
Stee Flo is offline   Reply With Quote
Old 03-14-2003, 07:19 PM   #5
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
I just got done replacing my starter. Try tapping the starter with a hammer or something. Then, try turning it on again. If it turns on keep turning it off and on probably like 5 times and if it doesn't turn on anymore try tapping the starter again to see if it turns on. If it does I'm pretty sure it's the starter.
-Juan
240Stilo is offline   Reply With Quote
