Old 03-25-2009, 09:51 PM   #1
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
Transmission sensors same? (Reverse & Neutral switch)
I have what looks to be one good Sensor (uninstalled) complete w/ Small harness and 2 sensors still in my SR trans w/ NO Plugs (but the Prongs coming off of them)
Not sure which is which but would they essientially be the same - would the Neutral Sensor,for instance,placed in the Reverse Spot Work?
Both act mechanically the same correct - what about Electricly?
trying to figure out if I need to Buy 1 more (for neutral) or try to make due using the Reverse one only (since its the only one Needed for reverse lights = anal.
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 03-26-2009, 12:39 AM   #2
projectRDM
projectRDM's Avatar
They're all the same, the plug on the reverse is different but can be clipped/rewired, otherwise any of them will work in any spot.
FORMERLY R240NA
Old 03-26-2009, 04:04 PM   #3
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
or plug them with an m14x1.5 I believe. Get some drain plugs off a civic
Bigsyke is offline   Reply With Quote
