Old 03-26-2009, 02:02 PM   #1
aziankingz
aziankingz's Avatar
Trader Rating: (28)
aziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really nice
Feedback Score: 28 reviews
Max HP for oem Exedy clutch
Anyone know what the maximum horsepower and/or torque the Exedy oem clutch can take? Would it be functional (with no slipping) at about 200-220rwhp?
aziankingz is offline   Reply With Quote
Old 03-26-2009, 02:07 PM   #2
slider2828
slider2828's Avatar
maybe..... I would use the stage 2....
Turn and Burn!
Old 03-26-2009, 03:07 PM   #3
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
Stock KA clutch?
Well, first things first - A clutch is rated by torque, not HP.
I had a T3 super-60 on a KA, making maybe ~220rwhp, 235-240rwtq...and it didn't even work for the test drive after the turbo install.
+200ft/lbs..and you'll need to upgrade the clutch.
Based on you saying "about 200-220rwhp"...I'll guess you're using a T25? If so, it'll spool QUICK, and make good low-end TQ...and the clutch WILL slip.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 03-26-2009, 03:53 PM   #4
aziankingz
aziankingz's Avatar
Trader Rating: (28)
Its a holset h1c - i guess ill have to put in a new clutch. The reason I am asking is because I put in the exedy clutch about a year ago and only put about 600 miles on it..
Old 03-26-2009, 03:58 PM   #5
TanaMU
TanaMU will become famous soon enoughTanaMU will become famous soon enoughTanaMU will become famous soon enoughTanaMU will become famous soon enough
For some crazy ass reason my excedy oem clutch is holding my ka-t's power (200-220 ish) just fine. Can't figure out why... No complaints though :P
TanaMU is offline   Reply With Quote
Old 03-26-2009, 04:00 PM   #6
slider2828
slider2828's Avatar
Once again its about torque and not HP. Depends also if you rail it.... OEM clutch is not going to hold 200ft/lb.... A stage 2 won't hold more than 275-300..... if it does, it will wear out quick...
Do it right, RPM Max Turbo Street disc... 300 ft/lb of torque at 4900RPM no problem for 2 years....
Turn and Burn!
Old 03-26-2009, 04:03 PM   #7
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
280 ft-lbs on Exedy Stage 1 for 1 year. No problems. I'm about to put 300+ through it and we'll see what happens...maybe it will force me to go to the Tilton setup.
Monooxide is offline   Reply With Quote
