Old 10-25-2001, 06:44 AM   #1
silvia240
silvia240's Avatar
silvia240 is an unknown quantity at this point
Here is a question for all of you.  What kind of suspension set up do you have and how bad is your camber and what did you use to fix it?
silvia240 is offline   Reply With Quote
Old 10-25-2001, 08:52 AM   #2
v8killer
v8killer is an unknown quantity at this point
First off, it seems like no matter how much you lower the car, there always seems like negative camber, because the wheels are so straight up-and-down to begin with. BUT, I know that there are bushings that you can buy that are urethane and offset to adjust- (cheap and PIA) -OR- you could go with Enjuku Racing's camber kit, found at their website for about 350.00. I can't seem to find the bushings now, but I'll keep looking, and post it when I find them...
Good Luck!
v8killer is offline   Reply With Quote
Old 10-25-2001, 08:56 AM   #3
TRM02
TRM02 is an unknown quantity at this point
Send a message via ICQ to TRM02
Is this what you are looking for ?
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE"> BRAND NEW and much anticipated, PDM is pleased to offer the new Whiteline KCA347 rear camber bush kit that replaces the original rear upper arm bushings to correct the normal camber gain associated with lowered 240SX's. This is the PROPER method to adjust rear camber in a 240SX vs slotting the upper rear arm, and a tremendous improvement for any lowered S13 or S14 as excessive negative rear camber leads to poor traction and handling and unwanted expensive inner tire wear. Designed with the inner metal bushing offset, a single kit will correct +/-0.75 degree change and 2 kits delivering +/-1.5 degrees.
240SX/300ZX (S13, S14 1989-1998)
Rear Camber Correction Bushings (KCA347) . . . . . $58.00/set</td></tr></table><span id='postcolor'>
TRM02 is offline   Reply With Quote
Old 10-25-2001, 09:00 AM   #4
v8killer
YES TRM! Thanks for helping me NOT become a liar!!!! &lt;whew&gt;! LOL
Old 10-25-2001, 09:02 AM   #5
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
Best way is to get yourself some Cusco Rear Upper Control Arms. They cost about $360 but they are badass and you can adjuste your camber setting for the rear.
It just so happens that I might sell mine off my car though. Let me know if your interested <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> hehe
West is offline   Reply With Quote
Old 10-25-2001, 09:19 AM   #6
TRM02
WeST, can I ask what you are going to do to correct your camber?
Old 10-25-2001, 09:38 AM   #7
West
OMNOMNOMNOM
West's Avatar
I already have a set of the Cusco Upper Control Arms, they are about a week old and just installed, but since I am selling my car I feel whomever buys it can fix there own camber since I wont get my $360 back from selling my car with them on there.
Old 10-25-2001, 02:29 PM   #8
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
West, how much do u need 2 recover........hint, hint?
burgy240 is offline   Reply With Quote
Old 10-25-2001, 04:47 PM   #9
West
OMNOMNOMNOM
West's Avatar
$300 Shipped...
The Cusco Components really do more then just fix camber. You will laugh at the stock control arms once they are off your car. They are a toothpick compared to the Cusco Arms. It made the rear end hook very well.
Old 10-25-2001, 11:17 PM   #10
mike2016
mike2016 will become famous soon enoughmike2016 will become famous soon enoughmike2016 will become famous soon enoughmike2016 will become famous soon enoughmike2016 will become famous soon enough
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from WeST on 4:47 pm on Oct. 25, 2001
$300 Shipped...
The Cusco Components really do more then just fix camber. You will laugh at the stock control arms once they are off your car. They are a toothpick compared to the Cusco Arms. It made the rear end hook very well.</td></tr></table><span id='postcolor'>
I'm interested, would you e-mail me at [email protected] if its still available? &nbsp;I don't post here often, i'm at freshalloy.com most time.... &nbsp;
mike2016 is offline   Reply With Quote
Old 10-26-2001, 10:39 AM   #11
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
hey mark why r u selling your car? what r u getting?
also....
i got the Eibach camber bolt for the fronts.
drifterx is offline   Reply With Quote
Old 10-27-2001, 03:27 AM   #12
wav399
wav399 is an unknown quantity at this point
Can you use the Cusco arms for a S13? &nbsp;and are these better for the car than the bushings pdm sells?
wav399 is offline   Reply With Quote
Old 10-28-2001, 05:17 AM   #13
silvia240
silvia240's Avatar
Hey west.... you are talking about only the rears.. right? &nbsp;It would be the lower control arms. &nbsp;And exactly how much degrees of camber will they ajust? &nbsp;Since you might be selling your car, how about throwing in your suspension for 100 bucks?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>?? hehehee...... Ohh and what about your fronts? What did you use of fix that?
Old 10-28-2001, 07:13 PM   #14
Guest
Posts: n/a
well for a stiff suspension a little bit of negative camber is good
Old 10-29-2001, 12:14 PM   #15
vancouvers14
vancouvers14 is an unknown quantity at this point
Send a message via ICQ to vancouvers14
sure, if you wanna visit your local tire store every 4 months
vancouvers14 is offline   Reply With Quote
