Old 04-16-2009, 09:52 PM   #1
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
SR Dry Start????
Well it started about 2 weeks ago and when i start my car i can hear the cams chatter and some knocking as in dosent sound lubricated, the oil light is on for the first 15 seconds and then it goes away and the car sounds normal. does anybody know what i need to replace? from what im hearing from a couple buddys is that the SR oil pump dosent go bad because its mechanical unless the teeth on the gears in it go bad. they told me either the oil filter collapased inside or the oil pick up is clogged or i need a new check valve or something. help please.
S13 curtis is offline   Reply With Quote
Old 04-16-2009, 09:56 PM   #2
Sileighty_85
Sileighty_85's Avatar
More than like likely the pump is going bad it common on 14-18 year old engines
check your oil pressure
Check/Pull the oil pan (make sure its not dented) and make sure the strainer is not being colgged
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-16-2009, 10:34 PM   #3
Def
Sounds like you're using a crappy oil filter without an anti-drainback valve like a Fram etc.
Use an OEM Nissan filter and I bet the problem goes away and you get oil pressure within a few seconds of startup.
Old 04-19-2009, 11:45 AM   #4
S13 curtis
S13 curtis's Avatar
its a really small mobil 1 oil filter.
Old 04-19-2009, 12:10 PM   #5
Banegraphix
Banegraphix's Avatar
Banegraphix is an unknown quantity at this point
I had the same problem and after switching oil filter brand it has never happened again. Either penzoil or K&N are what I have been using and it hasnt happened since.
Banegraphix is offline   Reply With Quote
