Old 04-19-2009, 04:58 PM   #1
180ways2slide
180ways2slide's Avatar
180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known
car just stopped working!??!
i have an sr20det and im running a microtech standalone with 4x msd coils etc.
now my problem is the car was idling in the driveway and all of a Sudden the car idles lower, then i hear it start to misfire, so i got to tap the gas and it dies completely and when i let off it runs again but really bad.my first thought was the gas was low and i needed gas, but now the car will start for a quicky( a real quicky ) and die. i did a self test on my laptop and the car has spark and the injectors are firing. fpr gauge is going up on cranking so i believe the pump is pumping.
where do i start to look now? has anyone had a similiar problem
180ways2slide is offline   Reply With Quote
Old 04-19-2009, 06:40 PM   #2
180ways2slide
SR
is it possible for the fuel pump to come on but not pump, cause after letting the car sit for a couple of hours it starts right up and then dies. and she will start up and die a couple of times, then nothing! now she is just cranking like i ran out of fuel. my walbro is only 2 weeks old can it be defective
Old 04-19-2009, 07:07 PM   #3
Sileighty_85
Sileighty_85's Avatar
If your Fuel pump works then check
TPS
IACV
MAF
Check those and the rest of the sensors
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-19-2009, 07:18 PM   #4
180ways2slide
tps is calibrated from microtech. iavc is not used andnot running a maf. but what color is the power wire to the fuel pump from the sender unit
