Old 04-21-2009, 05:09 PM   #1
Folken
Folken's Avatar
Folken is an unknown quantity at this point
Really boned my timing belt
okay so I replaced my HG and my did the timing belt on my ca18det, i go to crank it and she just cranks, I go to check the timing and the new belt is toast, the teeth are just destroyed for the most part, I have someone crank the car so i can look at the cams and they aren't moving but u can see the crank pulley, sprocket, w/e is spinning, anyone have a clue what I fucked up? btw the Timing was dead on and i torqued the camshafts down to spec
The beatings will continue until moral improves
Folken is offline   Reply With Quote
Old 04-21-2009, 05:24 PM   #2
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
Dude, as a practice, you should always spin the rotating assembly manually, meaning with a wrench on the crank bolt, before you start the car the first time after a major repair/install. You've obviously bound something in the head, pull the valve cover and take a look.
GL
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 04-21-2009, 05:33 PM   #3
Folken
Folken's Avatar
i did spin it, about 4 time over and i didn't have any crazy resistance, i can move the cams gears by hand
Old 04-21-2009, 07:10 PM   #4
DCP94
DCP94's Avatar
DCP94 is an unknown quantity at this point
you didnt hear any detonation did you?? may have bent a valve or 2.. its not in time anymore if the crank is spinning and the cams arent moving...thats what the belt is for to keep it in time..have fun with that
DCP94 is offline   Reply With Quote
