Old 10-23-2001, 01:45 PM   #1
Guest
Posts: n/a
what bol ons will really improve your sub 3500rpm power?
Old 10-23-2001, 02:06 PM   #2
Guest
Posts: n/a
cat-back exhaust
Old 10-23-2001, 02:24 PM   #3
Chokudori
Chokudori is an unknown quantity at this point
not those big ones though...
Chokudori is offline   Reply With Quote
Old 10-23-2001, 02:31 PM   #4
Guest
Posts: n/a
o0o run a straight pipe no muffler <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=':D'>
Old 10-23-2001, 02:40 PM   #5
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from nismos14 on 2<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>6 pm on Oct. 23, 2001
cat-back exhaust
</td></tr></table><span id='postcolor'>
I was just told the Apex-i n1 exhaust will make you lose a little low end but gain a lot of top end...is that correct?
Old 10-23-2001, 02:48 PM   #6
BlankFlip
BlankFlip's Avatar
BlankFlip is an unknown quantity at this point
yes it should do that. ur stock piping will actually give u more low-end than a cat-back exhaust b/c they're geared that way, but the top-end will definitely be improved.
BlankFlip is offline   Reply With Quote
Old 10-23-2001, 04:30 PM   #7
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from BlankFlip on 2:48 pm on Oct. 23, 2001
yes it should do that. ur stock piping will actually give u more low-end than a cat-back exhaust b/c they're geared that way, but the top-end will definitely be improved. </td></tr></table><span id='postcolor'>
so overall will I have a faster car if I get the N1 exhaust?
Old 10-23-2001, 04:35 PM   #8
Guest
Posts: n/a
so there's no bolt on's for low end power? what about a header?
Old 10-23-2001, 05:36 PM   #9
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
retarding your timing a little would give more low end right?
whateverjames is offline   Reply With Quote
Old 10-23-2001, 06:54 PM   #10
BlankFlip
BlankFlip's Avatar
yes, overall u'll have more power w/ a cat-back exhaust, u'll definitely notice it in higher rpm's. but sometimes having too big piping for an n/a won't exactly optimize ur performance, u'd be letting out 2 much air or exhaust. if u get an aftermarket intake like injen, u'll be taking in more air, then u'll need to get that air out efficiently, hence the cat-back exhausts. unfortunately most bolt-ons will take away some low-end, but the overall performance will be better, it's not like ur going to lose ALL of that low-end torque u like.
Old 10-23-2001, 07:34 PM   #11
MingMing
MingMing is an unknown quantity at this point
Send a message via ICQ to MingMing
if u mean retarding ur timing by letting the valves stay open a bit longer, that wont help ur low end either, cuz thats for high end when u can let in more fuel. &nbsp;u'll prolly stutter at low end...
and the right headers shud get u better low end, if they cause the air to spin right
cuz the faster the exhaust comes out of ur muffler, the better the performance of ur car, so at low end, there is less exhaust, and the smaller opening makes it shoot out faster, but at high end it becoems constricting, although with the proper header, u can make that air spin and it should improve performance in both low and top ends
MingMing is offline   Reply With Quote
